1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: FLIR camera bit depth configuration with ADSpinnaker
To: 'Florian Benedetti' <[email protected]>
Date: Wed, 16 Jun 2021 12:38:13 +0000
Hi Florian,
You have 2 problems.  This is the first one:
Ø  Unfortunately, I’m getting an error message if GC_PixelCoding enum is set to Mono12Packet:
2021/06/10 16:39:01.025 ADSpinnaker:grabImage: unsupported pixel format=0xb
Setting GC_PixelCoding to Mono12Packed does not actually cause the ADC to operate in 12-bit mode.  It just tells the camera to send the data with 2 12-bit pixel values packed into 3 bytes, to decrease the required bandwidth.  You are getting an error because when you select Mono12Packed you must also set the ConvertPixelFormat PV to Mono16 so that the 12-bit data is expanded to 16-bits in ADSpinnaker, which areaDetector can understand.
The second problem is with the data being 10-bit rather than 12-bit.  This is because you need to set a camera-specific GenICam feature to select the desired ADC bit depth.  That PV is called GC_AdcBitDepth, and you will find it on one of the camera-specific OPI screens.
From: Tech-talk <[email protected]> On Behalf Of Florian Benedetti via Tech-talk
Sent: Wednesday, June 16, 2021 7:22 AM
To: [email protected]
Subject: FLIR camera bit depth configuration with ADSpinnaker
Hello,
Sorry if it’s not directly related to areaDetector/EPICS but I have some issues when I try to configure the acquisition with Flir/PointGrey cameras, I’m using the ADSpinnaker module and I have GigE cameras (BFLY-PGE-23S6M) that should support 12 bits depth images according to the FLIR datasheet. Unfortunately, I’m getting an error message if GC_PixelCoding enum is set to Mono12Packet:
If GC_PixelCoding is set to 16bits instead, the acquisition works but the images remain at 10 bit depth.
Did I miss something during the configuration? How I can configure my cameras to work with 12 bit depth?
Thanks for your help.
Cheers.
Florian
RE:FLIR camera bit depth configuration with ADSpinnaker BENEDETTI Florian via Tech-talk
FLIR camera bit depth configuration with ADSpinnaker Florian Benedetti via Tech-talk
Prev: FLIR camera bit depth configuration with ADSpinnaker Florian Benedetti via Tech-talk
Next: Re: Re: Get timestamp from another IOC Zhang Yuliang via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: RE:FLIR camera bit depth configuration with ADSpinnaker BENEDETTI Florian via Tech-talk
