1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: EpicsSharp not reading PVs from EPICS gateway
From: Abdalla Ahmad via Tech-talk <[email protected]>
Date: Thu, 17 Jun 2021 13:38:03 +0000
Hi
I am facing an issue reading a PV from another VLAN using EPICS gateway. Assume we have two VLANs 1 and 2, the EPICS gateway is installed on a virtual server having a separate NIC for each VLAN and each NIC has an IP from the corresponding VLAN. A PC on VLAN 1 can caget a PV from VLAN 2, but an application using EpicsSharp on the same PC can’t read the same PV. I tried the “SearchAddress” property, setting EPICS_CA_ADDR_LIST and EPICS_CA_AUTO_ADDR_LIST=NO but nothing works. All of that while caget is working. What am I missing here?
Thanks in advance
Abdalla.
Prev: database could big data, compute and analyse 网易邮件中心 via Tech-talk
Next: Re: Get timestamp from another IOC Adrian Martinez via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Network Hardware Recommendation Josh Fiddler via Tech-talk
