1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: StreamDevice support problem: Cannot find a bus named 'L0' for...
To: Hasan SANSAR <[email protected]>
Date: Tue, 22 Jun 2021 12:56:48 +0000
Hi Hasan,
Your problem is this first error:
drvAsynIPPortConfigure("L0","10.97.4.4:8003",0,0,0)
st.cmd line 22: Command drvAsynIPPortConfigure not found.
You can see from the "help" output that indeed that command is not defined. That means your TDKtest application was not built with support for asyn and drvAsynIPPort.  You need to change the Makefile for building TDKtest to have lines like this:
TDKtest_DBD += asyn.dbd
TDKtest_DBD += drvAsynIPPort.dbd
For some reason you do have drvAsynSerialPort.dbd in your application, but not asyn.dbd or drvAsynIPPort.dbd.
From: Tech-talk <[email protected]> on behalf of Hasan SANSAR via Tech-talk <[email protected]>
Sent: Tuesday, June 22, 2021 7:45 AM
To: [email protected]
Subject: StreamDevice support problem: Cannot find a bus named 'L0' for...
I am a new member of EPICS platform. I installed EPICS R3.15.8.1-DEV from LaunchPad that given 'git' command on epics-contols.org and also StreamDevice and asyn from GitHub, and so I applied instructions on docs.epics-controls.org and there is no problem for installation and for example of creation IOC.
My environment is Debian GNU/Linux 10 Buster server installation without desktop GUI on Virtual Box. I'm trying to connect TDK-Lambda Z36-12-LAN Power Supply through ethernet connection with ethernet cable. There is no problem, because I can get ping from power supply's IP on Debian Virtualbox.
All in all, I start to follow Eric Norum's tutorial about device support (Or else, is it deprecated?):
https://epics.anl.gov/modules/soft/asyn/R4-24/HowToDoSerial/HowToDoSerial_StreamDevice.html
And I get error end of third step below. (I added several informations below of the error message.) I think stream does not detect asyn, but why?
~/EPICS/IOCs/TDK/iocBoot/iocTDKtest$ ./st.cmd
#!../../bin/linux-x86_64/TDKtest
## You may have to change TDKtest to something else
## everywhere it appears in this file
< envPaths
epicsEnvSet("IOC","iocTDKtest")
epicsEnvSet("TOP","/home/osiloskop/EPICS/IOCs/TDK")
epicsEnvSet("STREAM","/home/osiloskop/EPICS/support/StreamDevice")
epicsEnvSet "STREAM_PROTOCOL_PATH" "/home/osiloskop/EPICS/IOCs/TDK/db"
# Allow PV name prefixes and serial port name to be set from the environment
epicsEnvSet "P" "tdk_lambda"
epicsEnvSet "R" "Test"
epicsEnvSet "TTY" "10.97.4.4:8003"
cd "/home/osiloskop/EPICS/IOCs/TDK"
dbLoadDatabase "dbd/TDKtest.dbd"
TDKtest_registerRecordDeviceDriver pdbbase
# Set up ASYN ports
# drvAsynSerialPortConfigure port ipInfo priority noAutoconnect noProcessEos
asynSetTraceIOMask("L0",-1,0x2)
st.cmd line 23: Command asynSetTraceIOMask not found.
asynSetTraceMask("L0",-1,0x9)
st.cmd line 24: Command asynSetTraceMask not found.
## Load record instances
#dbLoadRecords("db/xxx.db","user=osiloskop")
dbLoadRecords("db/devTDK.db","P=tdk_lambda,R=Test,PORT=L0,A=0")
cd "/home/osiloskop/EPICS/IOCs/TDK/iocBoot/iocTDKtest"
iocInit
Starting iocInit
## EPICS R3.15.8.1-DEV
## EPICS Base built Jun 22 2021
2021/06/22 14:22:33.738076 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestIDN'
2021/06/22 14:22:33.738776 _main_ tdk_lambdaTestIDN: Can't attach to bus L0 0
2021/06/22 14:22:33.739342 _main_ tdk_lambdaTestIDN: Record initialization failed
2021/06/22 14:22:33.739909 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestIDNwf'
2021/06/22 14:22:33.740447 _main_ tdk_lambdaTestIDNwf: Can't attach to bus L0 0
2021/06/22 14:22:33.740981 _main_ tdk_lambdaTestIDNwf: Record initialization failed
2021/06/22 14:22:33.741510 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestGetSTB'
2021/06/22 14:22:33.742124 _main_ tdk_lambdaTestGetSTB: Can't attach to bus L0 0
2021/06/22 14:22:33.742664 _main_ tdk_lambdaTestGetSTB: Record initialization failed
2021/06/22 14:22:33.743210 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestGetESR'
2021/06/22 14:22:33.743758 _main_ tdk_lambdaTestGetESR: Can't attach to bus L0 0
2021/06/22 14:22:33.744297 _main_ tdk_lambdaTestGetESR: Record initialization failed
2021/06/22 14:22:33.744844 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestGetESE'
2021/06/22 14:22:33.745381 _main_ tdk_lambdaTestGetESE: Can't attach to bus L0 0
2021/06/22 14:22:33.746009 _main_ tdk_lambdaTestGetESE: Record initialization failed
2021/06/22 14:22:33.746585 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestGetSRE'
2021/06/22 14:22:33.747116 _main_ tdk_lambdaTestGetSRE: Can't attach to bus L0 0
2021/06/22 14:22:33.747660 _main_ tdk_lambdaTestGetSRE: Record initialization failed
2021/06/22 14:22:33.748211 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestGetOPC'
2021/06/22 14:22:33.748760 _main_ tdk_lambdaTestGetOPC: Can't attach to bus L0 0
2021/06/22 14:22:33.749291 _main_ tdk_lambdaTestGetOPC: Record initialization failed
2021/06/22 14:22:33.749879 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestSetESE'
2021/06/22 14:22:33.750409 _main_ tdk_lambdaTestSetESE: Can't attach to bus L0 0
2021/06/22 14:22:33.750946 _main_ tdk_lambdaTestSetESE: Record initialization failed
2021/06/22 14:22:33.751492 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestSetSRE'
2021/06/22 14:22:33.752026 _main_ tdk_lambdaTestSetSRE: Can't attach to bus L0 0
2021/06/22 14:22:33.752555 _main_ tdk_lambdaTestSetSRE: Record initialization failed
2021/06/22 14:22:33.753122 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestRST'
2021/06/22 14:22:33.753600 _main_ tdk_lambdaTestRST: Can't attach to bus L0 0
2021/06/22 14:22:33.754200 _main_ tdk_lambdaTestRST: Record initialization failed
2021/06/22 14:22:33.754888 _main_ Cannot find a bus named 'L0' for 'tdk_lambdaTestCLS'
2021/06/22 14:22:33.755377 _main_ tdk_lambdaTestCLS: Can't attach to bus L0 0
2021/06/22 14:22:33.755955 _main_ tdk_lambdaTestCLS: Record initialization failed
## Start any sequence programs
#seq sncxxx,"user=osiloskop"
epics> help
Type 'help <command>' to see the arguments of <command>.
#               ClockTime_Report                ClockTime_Shutdown
TDKtest_registerRecordDeviceDriver              asDumpHash      asInit
asSetFilename   asSetSubstitutions              ascar           asdbdump
asphag          aspmem          asprules        aspuag          astac
callbackParallelThreads         callbackSetQueueSize            casr
cd              coreRelease     date            dbDumpBreaktable
dbDumpDevice    dbDumpDriver    dbDumpField     dbDumpFunction  dbDumpMenu
dbDumpPath      dbDumpRecord    dbDumpRecordType
dbDumpRegistrar dbDumpVariable  dbLoadDatabase  dbLoadRecords   dbLoadTemplate
dbLockShowLocked                dbNotifyDump    dbPutAttribute  dbPvdDump
dbPvdTableSize  dbReportDeviceConfig            dbStateClear    dbStateCreate
dbStateSet      dbStateShow     dbStateShowAll  dba             dbap
dbb             dbc             dbcar           dbd             dbel
dbgf            dbgrep          dbhcr           dbior           dbl
dbla            dblsr           dbnr            dbp             dbpf
dbpr            dbs             dbsr            dbstat          dbtgf
dbtpf           dbtpn           dbtr            drvAsynSerialPortConfigure
echo            eltc            epicsEnvSet     epicsEnvShow    epicsEnvUnset
epicsMutexShowAll               epicsParamShow  epicsPrtEnvParams
epicsThreadResume               epicsThreadShow epicsThreadShowAll
epicsThreadSleep                errlog          errlogInit      errlogInit2
exit            generalTimeReport               gft             help
installLastResortEventProvider  iocBuild        iocInit         iocLogInit
iocLogPrefix    iocLogShow      iocPause        iocRun          iocshCmd
iocshLoad       iocshRun        pft             postEvent       pwd
registryDeviceSupportFind       registryDriverSupportFind       registryDump
registryFunctionFind            registryRecordTypeFind
scanOnceSetQueueSize            scanpel         scanpiol        scanppl
setIocLogDisable                streamReinit    streamReload
streamReportRecord              streamSetLogfile                taskwdShow
tpn             var
epics> drvAsynSerialPortConfigure
Port name missing.
epics> drvAsyn
Command drvAsyn not found.
epics> asynReport(10,SERIALPORT)
Command asynReport not found.
epics> dbior "stream"
Driver: stream
  StreamDevice 2.8.19-dirty 2021-04-09 17:41:57 +0200
  commit: 377d511c670193c5d49493ebcb5e7385fb34440a
  (C) 1999 Dirk Zimoch ([email protected]<mailto:[email protected]>)
  Use interest level 100 for license information
  registered bus interfaces:
    DebugInterface
    DummyInterface
    AsynDriverInterface
~/EPICS/IOCs/TDK/dbd$ grep -i stream TDKtest.dbd
device(stringin, INST_IO, devstringinStream, "stream")
device(stringout, INST_IO, devstringoutStream, "stream")
device(aao, INST_IO, devaaoStream, "stream")
device(mbbi, INST_IO, devmbbiStream, "stream")
device(bi, INST_IO, devbiStream, "stream")
device(waveform, INST_IO, devwaveformStream, "stream")
device(ao, INST_IO, devaoStream, "stream")
device(lso, INST_IO, devlsoStream, "stream")
device(mbbiDirect, INST_IO, devmbbiDirectStream, "stream")
device(longin, INST_IO, devlonginStream, "stream")
device(ai, INST_IO, devaiStream, "stream")
device(aai, INST_IO, devaaiStream, "stream")
device(longout, INST_IO, devlongoutStream, "stream")
device(mbbo, INST_IO, devmbboStream, "stream")
device(bo, INST_IO, devboStream, "stream")
device(mbboDirect, INST_IO, devmbboDirectStream, "stream")
device(lsi, INST_IO, devlsiStream, "stream")
device(calcout, INST_IO, devcalcoutStream, "stream")
driver(stream)
registrar(streamRegistrar)
variable(streamDebug, int)
variable(streamDebugColored, int)
variable(streamError, int)
$ ip a
1: lo: <LOOPBACK,UP,LOWER_UP> mtu 65536 qdisc noqueue state UNKNOWN group default qlen 1000
    link/loopback 00:00:00:00:00:00 brd 00:00:00:00:00:00
    inet 127.0.0.1/8 scope host lo
       valid_lft forever preferred_lft forever
    inet6 ::1/128 scope host
2: enp0s3: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 08:00:27:48:94:10 brd ff:ff:ff:ff:ff:ff
    inet 10.0.2.15/24 brd 10.0.2.255 scope global dynamic enp0s3
       valid_lft 67195sec preferred_lft 67195sec
    inet6 fe80::a00:27ff:fe48:9410/64 scope link
3: enp0s8: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 qdisc pfifo_fast state UP group default qlen 1000
    link/ether 70:54:d2:db:d2:d4 brd ff:ff:ff:ff:ff:ff
    inet6 fe80::7254:d2ff:fedb:d2d4/64 scope link
4: docker0: <NO-CARRIER,BROADCAST,MULTICAST,UP> mtu 1500 qdisc noqueue state DOWN group default
    link/ether 02:42:ce:4a:e5:26 brd ff:ff:ff:ff:ff:ff
    inet 172.17.0.1/16 brd 172.17.255.255 scope global docker0
$tail -5 ~/.bashrc
export EPICS_BASE=${HOME}/EPICS/epics-base
export EPICS_HOST_ARCH=$(${EPICS_BASE}/startup/EpicsHostArch)
export PATH=${EPICS_BASE}/bin/${EPICS_HOST_ARCH}:${PATH}
export ASYN=${HOME}/EPICS/support/asyn
export EPICS_DISPLAY_PATH=${ASYN}/opi/medm
~/EPICS/IOCs/TDK/dbd$ less ../../../support/asyn/configure/RELEASE
#RELEASE Location of external products
SUPPORT=/home/osiloskop/EPICS/support
#  IPAC is only necessary if support for Greensprings IP488 is required
#  IPAC release V2-7 or later is required.
#IPAC=$(SUPPORT)/ipac-2-15
# SEQ is required for testIPServer
#SNCSEQ=$(SUPPORT)/seq-2-2-5
## For sCalcout support in asynOctet - applications include asynCalc.dbd
#CALC=$(SUPPORT)/calc-3-7-3
# If CALC was built with SSCAN support then SSCAN must be defined for testEpicsApp
#SSCAN=$(SUPPORT)/sscan-2-11-3
#  EPICS_BASE 3.14.6 or later is required
EPICS_BASE=/home/osiloskop/EPICS/epics-base
-include $(TOP)/../RELEASE.local
-include $(TOP)/../RELEASE.$(EPICS_HOST_ARCH).local
-include $(TOP)/configure/RELEASE.local
less ../../../support/StreamDevice/configure/RELEASE
TEMPLATE_TOP=$(EPICS_BASE)/templates/makeBaseApp/top
# If you don't want to install into $(TOP) then
# define INSTALL_LOCATION_APP here
#INSTALL_LOCATION_APP=<fullpathname>
SUPPORT=${HOME}/EPICS/support
-include $(TOP)/../configure/SUPPORT.$(EPICS_HOST_ARCH)
ASYN=$(SUPPORT)/asyn
#PCRE=$(SUPPORT)/pcre-7-2
# EPICS_BASE usually appears last so other apps can override stuff:
# These lines allow developers to override these RELEASE settings
# without having to modify this file directly.
Thank you for your help in the future.
Best regards.
Hasan Sansar
Re: StreamDevice support problem: Cannot find a bus named 'L0' for... Hasan SANSAR via Tech-talk
Prev: StreamDevice support problem: Cannot find a bus named 'L0' for... Hasan SANSAR via Tech-talk
Next: Re: StreamDevice support problem: Cannot find a bus named 'L0' for... Hasan SANSAR via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
