1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: porting IOCs from Linux to RTEMS
From: "Siddons, David via Tech-talk" <[email protected]>
To: "Mooney, Tim M." <[email protected]>, EPICS Tech Talk <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 29 Jun 2021 21:03:00 +0000
Hi Tim,
  I'm sorry, I wasn't clear. I want this to be an RTEMS application, not a Linux application. We have been doing this with linux for several years, but only recently it seemed that RTEMS was more complete and robust than it used to be, so I'd like to explore that.
Pete.
Sent: Tuesday, June 29, 2021 5:00 PM
To: EPICS Tech Talk <[email protected]>; [email protected] <[email protected]>; Siddons, David <[email protected]>
Hi Pete,
I think Kiman Ha did that to make copies of softGlueZynq run at NSLS (because someone wanted to use the scaler in softGlueZynq).  As far as I know, Kiman's solution boots from the MicroSD card and autostarts an EPICS IOC.  You can run the EPICS IOC with or without softGlueZynq.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls Group (www.aps.anl.gov)
Advanced Photon Source, Argonne National Lab
From: Tech-talk <[email protected]> on behalf of Siddons, David via Tech-talk <[email protected]>
Sent: Tuesday, June 29, 2021 3:51 PM
Subject: porting IOCs from Linux to RTEMS
I need to build an EPICS IOC which can run without access to NFS mounts or TFTP mounts. The embedded system is a ZynQ-based system with ample persistent storage on a micro-SD card. It seems to me that libbsd provides a full range of file I/O facilities, and so a more Linux-like configuration should be possible. But I have no idea how to accomplish this! I suspect that I need to change ~/epics/base-7.0/modules/libcom/RTEMS/posix/rtems_init.c, since that seems to be where the NFS/TFTP stuff gets set up. Has anyone tried to do this?
Pete.
porting IOCs from Linux to RTEMS Siddons, David via Tech-talk
Re: porting IOCs from Linux to RTEMS Mooney, Tim M. via Tech-talk
Prev: Re: porting IOCs from Linux to RTEMS Mooney, Tim M. via Tech-talk
Next: Getting severity string from a PV in recent versions of EPICS Sobhani, Bayan via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
