1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: EPICS interface for Edwards nXDS scroll pump
From: Florian Feldbauer via Tech-talk <[email protected]>
To: Raymond Juras <[email protected]>, [email protected]
Date: Wed, 30 Jun 2021 23:27:39 +0200
Hey Ray,
we are using an nXDS scroll pump from edwards and controll it via StreamDevice + Asyn via the RS485 interface.
I've attached protocol and database files.
HTH,
Cheers,
Florian
On 6/30/21 10:50 PM, Raymond Juras via Tech-talk wrote:
Hello,
Has anyone developed an EPICS interface to the Edwards nXDS scroll pump?
Thank you,
Ray Juras
Oak Ridge National Laboratory
email: [email protected]
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
# ### EPICS Database for                ### #
# ### Edwards nXDS 15i                  ### #
# ### author: R.Kieser                  ### #
# ### Ref 1.0; 2014-01-06               ### #
# ### macros: subsys  PANDA subsystem   ### #
# ###         PORT    Asyn Interface    ### #
record (ai, "PANDA:$(subsys):VACUUM:FOREPUMP:Tmom") {
  field (DTYP, "stream")
  field (INP,  "@Edwards_nXDS15i.proto getTemperature $(PORT)")
# field (SCAN, "10 second")
  field (FLNK, "PANDA:$(subsys):VACUUM:FOREPUMP:Mfrequency")
record (ai, "PANDA:$(subsys):VACUUM:FOREPUMP:MotorFreqMom") {
  field (INP,  "@Edwards_nXDS15i.proto getMfrequency(PANDA:$(subsys):VACUUM:FOREPUMP) $(PORT)")
  field (FLNK, "PANDA:$(subsys):VACUUM:FOREPUMP:getRunTime")
record (mbbiDirect, "PANDA:$(subsys):VACUUM:FOREPUMP:Statusregister1") {
record (mbbiDirect, "PANDA:$(subsys):VACUUM:FOREPUMP:Statusregister2") {
record (mbbiDirect, "PANDA:$(subsys):VACUUM:FOREPUMP:Warnings") {
record (mbbiDirect, "PANDA:$(subsys):VACUUM:FOREPUMP:faultregister") {
record (ai, "PANDA:$(subsys):VACUUM:FOREPUMP:getError") {
  field (INP,  "@Edwards_nXDS15i.proto getError $(PORT)")
  field (PINI, "YES")
record (ai, "PANDA:$(subsys):VACUUM:FOREPUMP:getRunTime") {
  field (INP,  "@Edwards_nXDS15i.proto getRunTime $(PORT)")
# field (SCAN, "300 second")
record (bo , "PANDA:$(subsys):VACUUM:FOREPUMP:Pump") {
  field (OUT,  "@Edwards_nXDS15i.proto Pump $(PORT)")
  field (ZNAM, "OFF" )
  field (ONAM, "ON" )
# ### StreamDevice Protocol for             ### #
# ### Ref 1.0; 2013-12-19                   ### #
# ### Globals ### #
Terminator    = CR;
LockTimeout   = 5000;
ReplyTimeout  = 500;
ReadTimeout   = 500;
WriteTimeout  = 300;
ExtraInput    = Ignore;
# ### Protocols ### #
getTemperature {
  # get measured pump temperature
  # Example of command:
  # field (INP, "@Edwards_nxDS15i.proto getTemperature $(PORT)")
  out "?V808";
  in  "=V808 %u";
getMfrequency {
  # get motor frequncy and status words
  # field (INP, "@Edwards_nxDS15i.proto getMfrequency(PANDA:$(subsys):VACUUM) $(PORT)")
  out "?V802";
  in  "=V802 %u;%(\$1:Statusregister1)x;%(\$1:Statusregister2)x;%(\$1:Warnings)x;%(\$1:faulregister)x";
getError {
  # get fault history at last trip
  # field (INP, "@Edwards_nxDS15i.proto getError(PANDA:$(subsys):VACUUM) $(PORT)")
  out "?V816";
  in  "=V816 %x;%x;%x;%x";
getRunTime {
  # get Total run hours - time pump has run
  # field (INP, "@Edwards_nxDS15i.proto getRunTime $(PORT)")
  out "?V810";
  in  "=V810 %u";
Pump {
  # switch forepump on/off
  # field (OUT, "@Edwards_nxDS15i.proto Pump $(PORT)")
  out "!C802 %u";
  in  "*C802 %*u";
#  @init {
#    out "in_mode_05";
#    in  DC3,"%i";
EPICS interface for Edwards nXDS scroll pump Raymond Juras via Tech-talk
Prev: EPICS interface for Edwards nXDS scroll pump Raymond Juras via Tech-talk
Next: Using CALC value to set NELM in subArray Wang, Andrew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
