1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Using CALC value to set NELM in subArray
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Wang, Andrew" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 1 Jul 2021 15:31:39 +0000
Hi Andy,
On Jun 30, 2021, at 9:01 PM, Wang, Andrew via Tech-talk <[email protected]> wrote:
I want to use a calc record to determine what I want my NELM in a subArray record to be. I keep getting an error saying that there are no digits to convert. I feel like the problem is because the NELM field is ULONG, while the VAL field of the calc record is a DOUBLE. Don’t think it is possible to “cast” the DOUBLE to a ULONG in the calc record, unless I am wrong. Is there a way around this or is the best approach to use an aSub record?
The VAL field of a calc record holds a double, so even if you could cast the value in the _expression_ it would still be represented as a double result after the calculation was complete.
How are you copying your calc.VAL field value to the subArray.NELM field? I suspect that’s where your problem may be, are you trying to use NELM as a link? That would generate the “no digits to convert” error because NELM is a DBF_ULONG field so you can only set it to an integer numeric value in your .db file. Only DBF_LINK fields can point to other PVs. To copy the calc result into it I would use a calcout record and point its OUT link (which is a DBF_OUTLINKfield ) to the NELM field so its value will be copied.
If I’ve misunderstood what you’re doing, please post your .db file and the exact error message you’re getting; explicit examples are always much easier to debug than descriptions.
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Using CALC value to set NELM in subArray Wang, Andrew via Tech-talk
Prev: Question about "error calling writeRead" in modbus Wang, SuYin Grass via Tech-talk
Next: RE: EPICS compilation Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Using CALC value to set NELM in subArray Wang, Andrew via Tech-talk
Next: Re: Using CALC value to set NELM in subArray Wang, Andrew via Tech-talk
