1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: Question about the alive module
From: neu lzf via Tech-talk <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Mon, 5 Jul 2021 14:40:00 +0000
Dear all,
I start an soft IOC server in local computer and intend to monitor its running status by using alive record.
The IP address of the soft IOC is 127.0.0.1, then for alive record I set:
epicsEnvSet("ALIVE_SERVER","127.0.0.1") in st.cmd and I use its default example db as a test, then I start the alive record.
My problem is when "dbpr aliveEx:alive", the SEVR is always INVALID, I have no idea if I miss something and which program should I need to install to make the alive record work.
Thank you very much in advance and an example step for starting alive record is appreciated.
Prev: pythonIoc is now a python package rather than an EPICS support module Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Next: Re: EPICS compilation Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Prev: pythonIoc repo renamed to pythonSoftIOC Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Next: Re: Question about the alive module Dohn Arms via Tech-talk
ANJ, 15 Jul 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
