1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Read I2C data with EPICS
From: Florian Feldbauer via Tech-talk <[email protected]>
To: [email protected]
Date: Tue, 6 Jul 2021 17:58:29 +0200
Hey Steve,
for the Raspberry Pi I build a device support module to interact with the I2C interface via Asyn and Stream.
https://github.com/ffeldbauer/drvAsynI2C
This package requires a little patch to streamdevice though to make stream device aware of this asyndriver
Maybe this helps
Florian
Am 06.07.2021 um 17:48 schrieb Mark Rivers via Tech-talk:
Hi Steve,
This is a fine place to ask that question.
The I2C data could be put into a waveform record and then you can read it with caget.
Can you explain what type of device you are using with I2C and what information do you want to read or write?  Sending binary data to an EPICS client like you describe is not the typical way that EPICS is used.  The EPICS IOC typically converts that binary data from the device into a more human friendly format, like temperature values, etc.
From: Tech-talk <[email protected]> on behalf of Steve Hu via Tech-talk <[email protected]>
Sent: Tuesday, July 6, 2021 3:34 AM
Subject: Read I2C data with EPICS
Hello,
I started to use EPICS recently and currently I am learning to use it. I am a french student and I apologize in advance for my bad English.
I just have one question but I don't know if I am in the right place to ask so please tell me if that is the case.
For a project, my internship supervisor want me to use i2c through EPICS and my last problem is to read the data with EPICS IOC like 0x00 0x01 0x02... Is it possible to read these type of data with caget ?
I thank you in advanced for your help.
Sincerely,
Steve Hu.
Ruhr-Universität Bochum
AG der Experimentalphysik I
Dr. Florian Feldbauer
NB 2/131 / Fach 125
Universitätsstr. 150
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Read I2C data with EPICS Steve Hu via Tech-talk
Re: Read I2C data with EPICS Mark Rivers via Tech-talk
Prev: Re: Read I2C data with EPICS Mark Rivers via Tech-talk
Next: WG: Read I2C data with EPICS Loeher, Bastian Dr. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
