1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: linking in IOC makefile for RTEMS
From: "Siddons, David via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Sun, 18 Jul 2021 18:41:35 +0000
Hi Michael,
   OK, you are right. That fixed the symbol problem and it now tries to mount the filesystem. Booting the resultant image I get:
***** Setting up file system *****
----- try to mount local filesystem ------
***** Using compiled in file data *****
*** FATAL ***
fatal source: 9 (RTEMS_FATAL_SOURCE_EXCEPTION)
R0   = 0x62726174 R8  = 0x00000000
R1   = 0x00000000 R9  = 0x00000000
R2   = 0x80812ce8 R10 = 0x00000000
R3   = 0x80856040 R11 = 0x00000000
R4   = 0x80456f50 R12 = 0x00000000
R5   = 0x80869198 SP  = 0x808690f0
R6   = 0x00000000 LR  = 0x801a997c
R7   = 0x00000000 PC  = 0x801aa73c
CPSR = 0x40000113 VEC = 0x00000004
RTEMS version: 5.0.0.1b3f09251ae53a93ea647e4d8ebeffeead91a880
RTEMS tools: 7.5.0 20191114 (RTEMS 5, RSB 5 (1b3f09251ae5), Newlib 7947581)
executing thread ID: 0x08b010001
executing thread name:
The image was generated using the attached script, make-tarball.sh, and the current Makefile is also attached.
Pete.
Sent: Saturday, July 17, 2021 2:44 PM
To: Siddons, David <[email protected]>
Cc: EPICS tech-talk <[email protected]>; Johnson, Andrew N. <[email protected]>
On 7/16/21 12:47 PM, Siddons, David via Tech-talk wrote:
> Hi Andrew,
>   It doesn't seem to. The file is clearly compiled and included in the support library:
> /home/peter/quick-start/rtems/5/bin/arm-rtems5-ar rc   libmyexampleSupport.a    xxxRecord.o devXxxSoft.o dbSubExample.o devmyexampleVersion.o myexampleHello.o initTrace.o tarball.o
I'm not sure my 'epicsRtemsFSImage' trick will work from a library.
Try moving tarball.c to myexample_SRCS.
> myexample_SRCS += tarball.c
And I think you can just remove '..._SRCS += tarball.h'.
It's probably not doing anything helpful.
> arm-rtems5-nm libmyexampleSupport.a |grep epicsRtems
> 00000000 R epicsRtemsFSImage
> 00000000 R epicsRtemsFSImage_size
> but not in the myexample executable:
> peter@peter-OptiPlex-7070:~/test_ioc/bin/RTEMS-beagleboneblack$ arm-rtems5-nm myexample |grep epicsRtems
> 8060306c V epicsRtemsFSImage
> which is the weak symbol.
> Pete.
> *From:* Johnson, Andrew N. <[email protected]>
> *Sent:* Friday, July 16, 2021 3:21 PM
> *To:* Siddons, David <[email protected]>
> *Cc:* EPICS tech-talk <[email protected]>
> *Subject:* Re: linking in IOC makefile for RTEMS
> Hi Pete,
> Just an idea, does it make any difference if you remove the tarball.h file from your _SRCS variable (you shouldn’t include .h files in _SRCS anyway, if you want to install them they go into INC instead)?
> - Andrew
>> On Jul 16, 2021, at 2:08 PM, Siddons, David via Tech-talk <[email protected] <mailto:[email protected]>> wrote:
>> I have an RTEMS test IOC (generated using makeBaseApp) to which I've added a source file which declares a large array (actually, a compiled-in file system). The Makefile has:
>> # rather than directly into the IOC application, that
>> # causes problems on Windows DLL builds
>> myexampleSupport_SRCS += dbSubExample.c
>> myexampleSupport_SRCS += devmyexampleVersion.c
>> myexampleSupport_SRCS += myexampleHello.c
>> myexampleSupport_SRCS += initTrace.c
>> myexampleSupport_SRCS += tarball.h
>> myexampleSupport_SRCS += tarball.c
>> where the tarball files are my additions. The C file contains:
>>  *  Declarations for C structure representing binary file epicsRtemsFSImage
>>  *  WARNING: Automatically generated -- do not edit!
>> #include <sys/types.h>
>> const unsigned char epicsRtemsFSImage[] = {
>>   0x74, 0x61, 0x72, 0x62, 0x61, 0x6c, 0x6c, 0x2f, 0x00, 0x00, 0x00, 0x00,
>>   0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
>>   .....etc, then:
>> const size_t epicsRtemsFSImage_size = sizeof(epicsRtemsFSImage);
>> The EPICS base libraries contain a weak reference to this same symbol (from libcom/RTEMS/init.c) , and I expected this definition to overwrite the weak one, but inspection of the executable only shows the weak one, and the size variable is not referenced at all. What am I missing? It seems that the tarball file is compiled, but not linked.
>> Pete.
> Complexity comes for free, simplicity you have to work for.
Attachment: make-tarball.sh
Description: make-tarball.sh
Attachment: Makefile
Description: Makefile
Re: linking in IOC makefile for RTEMS Michael Davidsaver via Tech-talk
linking in IOC makefile for RTEMS Siddons, David via Tech-talk
Re: linking in IOC makefile for RTEMS Johnson, Andrew N. via Tech-talk
Re: linking in IOC makefile for RTEMS Siddons, David via Tech-talk
Prev: Re: linking in IOC makefile for RTEMS Michael Davidsaver via Tech-talk
Next: Re: linking in IOC makefile for RTEMS Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
