1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Drivers for Thorlabs camera, Gentec power meter?
From: "Feister, Scott via Tech-talk" <[email protected]>
Date: Wed, 28 Jul 2021 20:58:46 +0000
Mark,
Thanks! I am hoping to retrofit EPICS into an existing plasma diagnostic already built with that camera. Those are important drawbacks to know about – thank you for sharing them. I will explore whether we can eventually replace this with a different camera, or if it can’t be replaced, explore developing an areaDetector integration using the Windows SDK, down the road.
To follow up to the user group on my second question: is anyone using the Gentec S-Link-2-Ethernet power meters?
Scott
Sent: Wednesday, July 28, 2021 1:51 PM
To: Feister, Scott <[email protected]>
Cc: [email protected]
CAUTION: This email originated from outside of CSUCI. Do not click links or open attachments unless you validate the sender and know the content is safe. Contact ITS if you have any concerns
Hi Scott,
I don’t know of areaDetector support for those Thorlabs cameras.  I have looked at them before when others inquired about them.  They have a few disadvantages to be aware of:
  • They are not GenICam compliant, which means that ADAravis cannot be used with them.
  • The vendor SDK only supports Windows, so you cannot use Linux.
  • They only support rolling shutter, not global shutter.  That means that each row of your image is acquired at a different time, they are not synchronous.  That may or may not be an issue for your application.
From: Tech-talk <[email protected]> On Behalf Of Feister, Scott via Tech-talk
Sent: Wednesday, July 28, 2021 3:32 PM
To: EPICS tech-talk <[email protected]>
Subject: Drivers for Thorlabs camera, Gentec power meter?
Hi EPICS users,
I have two inquiries about current drivers:
  1. Is anyone currently using areaDetector for this Thorlabs camera: Thorlabs CS2100M-USB (https://www.thorlabs.com/newgrouppage9.cfm?objectgroup_id=11421)
  2. Is anyone using a driver with the Gentec S-Link-2-Ethernet power meter base station? (https://www.gentec-eo.com/products/s-link-2-ethernet)
    1. E.g. I found this from Marek Böhm in the archives of tech-talk: https://epics.anl.gov/tech-talk/2015/msg00751.php
Thanks!
Scott
Scott Feister
Assistant Professor, California State University Channel Islands
Drivers for Thorlabs camera, Gentec power meter? Feister, Scott via Tech-talk
RE: Drivers for Thorlabs camera, Gentec power meter? Mark Rivers via Tech-talk
Prev: RE: Drivers for Thorlabs camera, Gentec power meter? Mark Rivers via Tech-talk
Next: Re: CA Gateway converts int/float value to hex Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: CA Gateway converts int/float value to hex andrej.manojlovic--- via Tech-talk
