1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Stream device: Reading values from two almost identical input strings using I/O intr
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 29 Jul 2021 11:59:02 +0200
On Thu, 29 Jul 2021 at 11:55, Ralph Lange <[email protected]> wrote:
I think your best bet is to use a single format, write the number and the tag in two separate records, and FLNK a combination of calcout then seq to forward the number to where it belongs.
Three. (I missed the units.)
I think your best bet is to use a single format, write number, units and tag in three separate records, and FLNK a combination of calcout (on the tag) then seq (in mask mode) to forward number and unit where they belong.
~Ralph
Stream device: Reading values from two almost identical input strings using I/O intr Nicklas Bjärnhall Prytz via Tech-talk
Re: Stream device: Reading values from two almost identical input strings using I/O intr Ralph Lange via Tech-talk
Prev: Re: Stream device: Reading values from two almost identical input strings using I/O intr Ralph Lange via Tech-talk
Next: Re: [EXTERNAL] Phoebus Archive xml config file: Automate generation, using Autosave module of synApps?? Kuldeep Joshi via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: Stream device: Reading values from two almost identical input strings using I/O intr Zimoch Dirk (PSI) via Tech-talk
