1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Phoebus Archive xml config file: Automate generation, using Autosave module of synApps??
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: Kuldeep Joshi <[email protected]>
Date: Thu, 29 Jul 2021 13:18:50 +0000
> I guess if we restrict to only generating the .req file, this way the solution will be quite nifty. Adding the xml generation library to it will make it bulky.
> I suggest a two stage solution, the makeArchiveConfigFile will make a .req file. Each line of this .req file will contain all the necessary archive information per PV. This file can subsequently be parsed using a python app for generating a CSS archive compatible xml config file.
> We can extend the AutosaveFileFromDbInfo function and request the maintainer if this can be a standard feature of autosave.
The information that you need is
1) How to sample: scan or monitor
2) How often to do that, i.e. scan period or estimated update period
3) PV name, which usually is the record name with implied .VAL, but in rare cases you might for example want the .RBV
Example:
  # Request archiving on change
  info(archive, "Monitor, 00:01:00")
  # Scan
  info(archive, "Scan, 01:00:00")
  # VAL field is the default
  info(archive, "Monitor, 00:01:00, VAL")
  # In rare cases, might need to archive other fields
  info(archive, "Monitor, 00:01:00, RVAL DMOV")
Why do you want to add this to the autosave/restore code? They're not related.
Why do you want to create some arbitrary intermediate file format?
Why not create the XML right away?
Yes, I would avoid adding an XML library, but "printf" will suffice since you know what you'll write. Just check the PV names for a very limited number of potential characters to escape, which I think is basically '>' and '<'.
So something like ` makeArchiveConfigFile("/path/to/ioc_xyz_archive.xml")` at the end of st.cmd will create one file per IOC, and you can then use xinclude to merge the per-IOC files into one per archive engine.
-Kay
Re: [EXTERNAL] Phoebus Archive xml config file: Automate generation, using Autosave module of synApps?? Michael Davidsaver via Tech-talk
Phoebus Archive xml config file: Automate generation. Kuldeep Joshi via Tech-talk
Re: [EXTERNAL] Phoebus Archive xml config file: Automate generation. Kasemir, Kay via Tech-talk
Phoebus Archive xml config file: Automate generation, using Autosave module of synApps?? Kuldeep Joshi via Tech-talk
Re: [EXTERNAL] Phoebus Archive xml config file: Automate generation, using Autosave module of synApps?? Kasemir, Kay via Tech-talk
Re: [EXTERNAL] Phoebus Archive xml config file: Automate generation, using Autosave module of synApps?? Kuldeep Joshi via Tech-talk
Prev: Re: [EXTERNAL] Phoebus Archive xml config file: Automate generation, using Autosave module of synApps?? Ralph Lange via Tech-talk
Next: Arbitrary rotation angle with areaDetector Plugin Smith, William via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: [EXTERNAL] Phoebus Archive xml config file: Automate generation, using Autosave module of synApps?? Michael Davidsaver via Tech-talk
