1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: ADVimba image acquisition issues
To: "Wlodek, Jakub" <[email protected]>
Date: Sat, 31 Jul 2021 12:08:09 +0000
Hi Jakub,
One thing that can prevent the camera from streaming is if the Ethernet packet size is set incorrectly.  That is PV GC_GeVSCPSPacketSize.  On my Manta camera that is on the camera-specific screen #1.
However, if that is the problem then you should see error messages on the IOC.  It also should be auto-negotiated correctly when the camera connects.
From: Tech-talk <[email protected]> on behalf of Wlodek, Jakub via Tech-talk <[email protected]>
Sent: Friday, July 30, 2021 3:21 PM
To: [email protected]
Subject: ADVimba image acquisition issues
Hi all,
Recently I have been working on diagnosing some problems with image stream freezing for some Prosilica cameras at one of our beamlines. At the moment they are all still using the ADProsilica driver, which can collect images from the camera just fine, but there is a problem where image stream will stop intermittently requiring an IOC reboot. As a potential troubleshooting step, I decided it would be worth trying the ADVimba driver, since that uses an underlying API that is still supported. Unfortunately, while the new ADVimba based IOC can connect to the camera and reports the model number, firmware version etc. the image stream never starts after starting acquisition.
I have played around with the various TriggerMode and TriggerSource options, but for every combination the only thing that happens when pressing "Acquire" is the detector state changes to "Waiting", but image rate remains 0 and no messages appear in the IOC shell.
Is there something else I am missing to get this to work? Some background information:
ADCore Version: R3-10
EPICS Base Version: R7.0.5
ADGenICam Version: R1-8
ADVimba Version: master branch (As of this email)
Camera model: AVT_Manta_GT1290
I can also send over any other pertinent information.
Thanks in advance,
Jakub
ADVimba image acquisition issues Wlodek, Jakub via Tech-talk
Prev: Re: StreamDevice protocol file question Zimoch Dirk (PSI) via Tech-talk
Next: Phoebus Touch Screen Issue Kuldeep Joshi via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: ADVimba image acquisition issues Mark Rivers via Tech-talk
