1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: [EXTERNAL] Re: Autostart with manage-procs and network mounts
From: Ernesto Paiser via Tech-talk <[email protected]>
To: [email protected]
Date: Tue, 3 Aug 2021 10:59:06 -0700
Hi guys,
I used this below in the remote server and always started the IOCs with procServ from a nfs mounting point.
file: /usr/lib/systemd/system/ioc.service
[Unit]
Description=IOC Process Manager
After=multi-user.target
Requires=multi-user.target
[Service]
Type=oneshot
ExecStart=/usr/lib/systemd/scripts/ioc.sh
RemainAfterExit=yes
[Install]
WantedBy=multi-user.target
On 8/3/21 10:34 AM, Michael Davidsaver via Tech-talk wrote:
CAUTION: *** EMAIL ORIGINATED FROM OUTSIDE THE ORGANIZATION. Please do not click links or open attachments unless you know the contents are safe. Verify that you recognize sender email address before clicking any link or attachment. DO NOT enter/change any password when clicking on a link. ***
On 8/3/21 10:22 AM, Kasemir, Kay wrote:
I am using manage-procs to deploy and manage IOC’s using systemd. ..network drive over nfs at boot that contains the built IOC binaries
I think that "After=network.target remote-fs.target" should be enough to ensure ordering.  You could try adding
"Requires=network.target remote-fs.target".
I think we had similar issues with network mounts not being up in time for the IOCs to start when we had just this in the IOC systemd files:
Requires=autofs.service
The following belt-and-suspenders approach fixed the problem, though I'm not sure exactly why:
I would be reluctant to blindly add this as I think it would make manage-procs
unusable by default for installations w/o autofs.  If a Requires= turns out to
be necessary, manage-procs would probably have to detect this somehow.
This is actually redundant to "BindsTo=autofs.service".
After=autofs.service
This seems reasonable, and would hopefully be sufficient by itself.
Wants=autofs.service
This should probably be ok, but would need some testing.  I would expect that
if autofs is installed, that it is installed and should be running.
cf. https://nam10.safelinks.protection.outlook.com/?url=https%3A%2F%2Fwww.freedesktop.org%2Fsoftware%2Fsystemd%2Fman%2Fsystemd.unit.html%23Wants%3D&amp;data=04%7C01%7Cernesto_paiser%40lynceantech.com%7C8957d5d1168e456191d808d956a4fcb7%7C49fa64a600cf42d48c52cc94b9a02f26%7C1%7C0%7C637636088892767139%7CUnknown%7CTWFpbGZsb3d8eyJWIjoiMC4wLjAwMDAiLCJQIjoiV2luMzIiLCJBTiI6Ik1haWwiLCJXVCI6Mn0%3D%7C1000&amp;sdata=FPXFNVRz%2FIbW76Z2C5V37QY243PGEny2ILT4Ws%2FaBcs%3D&amp;reserved=0
Autostart with manage-procs and network mounts Smith, William via Tech-talk
Re: Autostart with manage-procs and network mounts Michael Davidsaver via Tech-talk
Re: [EXTERNAL] Re: Autostart with manage-procs and network mounts Kasemir, Kay via Tech-talk
Re: [EXTERNAL] Re: Autostart with manage-procs and network mounts Michael Davidsaver via Tech-talk
Prev: Re: [EXTERNAL] Re: Autostart with manage-procs and network mounts Michael Davidsaver via Tech-talk
Next: Re: Autostart with manage-procs and network mounts Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: RE: Autostart with manage-procs and network mounts Smith, William via Tech-talk
