1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: Archive appliance on RHEL8
From: "Sinclair, John via Tech-talk" <tech-talk at aps.anl.gov>
To: tech-talk <tech-talk at aps.anl.gov>
Date: Tue, 3 Aug 2021 19:21:58 +0000
Has anyone installed the archive appliance on RHEL8?
I can't get past the following error:
Pointing a browser at http://localhost:17665/mgmt gives:
HTTP Status 500 – Internal Server Error
Type Status Report
Message The config service for this installation did not start up correctly. Please check the logs for any exceptions or FATAL errors. Unable to determine applianceinfo using identity dev-ics-nnl2.ics.sns.gov <i>org.epics.archiverappliance.config.exception.ConfigException: Unable to determine applianceinfo using identity dev-ics-nnl2.ics.sns.gov at org.epics.archiverappliance.config.DefaultConfigService.initialize(DefaultConfigService.java:255) at org.epics.archiverappliance.config.ArchServletContextListener.contextInitialized(ArchServletContextListener.java:44) at org.apache.catalina.core.StandardContext.listenerStart(StandardContext.java:4763) at org.apache.catalina.core.StandardContext.startInternal(StandardContext.java:5232) at org.apache.catalina.util.LifecycleBase.start(LifecycleBase.java:183) at org.apache.catalina.core.ContainerBase.addChildInternal(ContainerBase.java:755) at org.apache.catalina.core.ContainerBase.addChild(ContainerBase.java:729) at org.apache.catalina.core.StandardHost.addChild(StandardHost.java:695) at org.apache.catalina.startup.HostConfig.deployWAR(HostConfig.java:1016) at org.apache.catalina.startup.HostConfig$DeployWar.run(HostConfig.java:1903) at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:511) at java.util.concurrent.FutureTask.run(FutureTask.java:266) at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) at java.lang.Thread.run(Thread.java:748) </i>
Description The server encountered an unexpected condition that prevented it from fulfilling the request.
I have tried tomcat 8 and 9, both with java 8 and 11 and I get a similar message. For tomcat 9, the message involves more functions but the problem is the same.
John Sinclair
Re: Archive appliance on RHEL8 Michael Davidsaver via Tech-talk
Prev: Re: Autostart with manage-procs and network mounts Michael Davidsaver via Tech-talk
Next: Re: Archive appliance on RHEL8 Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Prev: RE: Getting started with EPICS lecture videos Leblanc, Gregory via Tech-talk
ANJ, 06 Aug 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
