1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Lib directory is not created for RTEMS (EPICS 7).
From: Michael Davidsaver via Tech-talk <[email protected]>
To: cristian ramos <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 4 Aug 2021 08:32:14 -0700
On 8/4/21 7:49 AM, cristian ramos via Tech-talk wrote:
> Hello,
>      I am writing to see if you can give me some guidance on the following error I am having. I am trying to migrate a module from EPICS 3.15.8 to EPCIS 7. The module compiles correctly, except that when I invoke the make command for RTEMS the lib directory is not created automatically. If I change the macro in the Makefile to compile for the other platforms, in this case, linux_x86_64 the lib directory is created when the make command is invoked. Basically, by declaring the macro LIBRARY_IOC_RTEMS += <module_name_lib>, the lib directory is not created when invoking make, whereas if you change the macro to
> LIBRARY_IOC += <module_name_lib> the lib directory is created.
>     To provide more information, with the previous version (EPICS 3.15.8) it behaves as expected but with EPICS 7, this is not the case. Maybe I need to take something into account with the new version of EPICS to have the same effect as with the previous version.
Which RTEMS version and target(s) are you using?
Lib directory is not created for RTEMS (EPICS 7). cristian ramos via Tech-talk
Prev: Re: Autostart with manage-procs and network mounts Michael Davidsaver via Tech-talk
Next: Re: Lib directory is not created for RTEMS (EPICS 7). Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Lib directory is not created for RTEMS (EPICS 7). cristian ramos via Tech-talk
