1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Archive appliance on RHEL8
From: "Shankar, Murali via Tech-talk" <[email protected]>
Date: Wed, 4 Aug 2021 18:30:48 +0000
It might help to see these log lines from the mgmt's arch.log. Specifically, we should see something like so
2    [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  -
2    [main] INFO  org.epics.archiverappliance.config.DefaultConfigService  - Obtained my identity from environment variable test-arch
2    [main] INFO  org.epics.archiverappliance.config.DefaultConfigService  - My identity is test-arch
3    [main] INFO  org.epics.archiverappliance.config.AppliancesList  - appliances.xml file specified in the environment as /scratch/.../single_VM_appliances.xml
11   [main] INFO  config.org.epics.archiverappliance.config.DefaultConfigService  - My identity is test-arch and my mgmt URL is http://test-arch.slac.stanford.edu:17665/mgmt/bpl
The identity, "Obtained my identity from environment variable" comes from the environment variable ARCHAPPL_MYIDENTITY. This should match an appliance definition in the appliances.xml "appliances.xml file specified in the environment as /scratch/.../single_VM_appliances.xml" specified using the environment variable ARCHAPPL_APPLIANCES.
Murali
Prev: RE: Autostart with manage-procs and network mounts Smith, William via Tech-talk
Next: RE: cbLow consumption randomly stopping Daykin, Evan via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Archive appliance on RHEL8 Michael Davidsaver via Tech-talk
Next: archive appliance Sinclair, John via Tech-talk
