1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: cbLow consumption randomly stopping
From: "Daykin, Evan via Tech-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>, "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 5 Aug 2021 16:25:05 +0000
Yes, there are other support modules:
Calc, Tbuf (time buffer for pico8), PyDevSup, SScan, autosave, iocstats, and caputlog.
If I set the IOC back to 1 thread with all four cards, the shell is spammed with output:
DIAG_MTCA17:PICO8_CH0:MIN_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH1:MIN_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH2:MIN_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH3:MIN_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH4:MIN_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH5:MIN_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH6:MIN_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH7:MIN_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH0:MAX_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH1:MAX_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH2:MAX_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH3:MAX_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH4:MAX_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH5:MAX_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH6:MAX_ASUB: repeated sample (diff=0.000000) [1 times]
DIAG_MTCA17:PICO8_CH7:MAX_ASUB: repeated sample (diff=0.000000) [1 times]
I assume this is because there is some bottleneck. If I reduce to 1 thread and 1 hardware device, the output is gone. So, with the following in mind:
-1 thread is too slow for four devices
-multiple threads is untested
Is the best workaround to split these into multiple IOCs?  That way, I assume, there is parallel processing without untested resource contention.
-----Original Message-----
Sent: Thursday, August 5, 2021 11:41 AM
To: Johnson, Andrew N. <[email protected]>; Daykin, Evan <[email protected]>
Cc: EPICS tech-talk <[email protected]>; Rivers, Mark L. <[email protected]>
Subject: Re: cbLow consumption randomly stopping
[EXTERNAL] This email originated from outside of FRIB
On 8/5/21 8:30 AM, Johnson, Andrew N. wrote:
> Hi Evan,
> Does this IOC load /any/ other EPICS drivers or device support at all (other than the standard ones that come with Base)?
> Your configuration with multiple callback threads is unusual, and a lot of device/driver support might not have been written or tested with the thought that there could more than one such callback in mind, so any such support code might be contributing to this issue.
I'll second this.  I never tested the pico8 driver (or any of my
drivers) with parallel callbacks enabled.
Re: cbLow consumption randomly stopping Michael Davidsaver via Tech-talk
cbLow consumption randomly stopping Daykin, Evan via Tech-talk
Re: cbLow consumption randomly stopping Mark Rivers via Tech-talk
RE: cbLow consumption randomly stopping Daykin, Evan via Tech-talk
Re: cbLow consumption randomly stopping Johnson, Andrew N. via Tech-talk
Prev: Re: How to find out PVs preventing SSCAN from running? Li, Ji via Tech-talk
Next: Re: How to find out PVs preventing SSCAN from running? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: cbLow consumption randomly stopping Michael Davidsaver via Tech-talk
Next: Re: cbLow consumption randomly stopping Michael Davidsaver via Tech-talk
