1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: ADURL with Axis PTZ network camera
To: 'Katie Matusik' <[email protected]>, "Heesterman, Peter J" <[email protected]>
Date: Tue, 10 Aug 2021 16:59:42 +0000
Ø  Actually, I just increased the acquire period to be closer to the frame rate of the web cam (0.08s) and it updates much faster now. So it seems like 1s output was too slow and added some latency?
I’m glad it’s working, but I would like to understand the behavior when AcquirePerious=1.  On your screen shot the Image rate was reported as 1.00.  Was that always 1.00 or did it fluctuate?  If it was always 1.00 then that means it really was receiving 1 frames/s as it should.  What happens to the Image rate value as you vary the AcquirePerioud (1.0, 0.5, 0.25, .1, etc.)?
Sent: Tuesday, August 10, 2021 11:52 AM
To: Heesterman, Peter J <[email protected]>
Cc: Mark Rivers <[email protected]>; EPICS Tech Talk <[email protected]>
Subject: Re: ADURL with Axis PTZ network camera
Actually, I just increased the acquire period to be closer to the frame rate of the web cam (0.08s) and it updates much faster now. So it seems like 1s output was too slow and added some latency? Thanks so much for all the help.
-Katie
On Tue, Aug 10, 2021 at 9:47 AM Katie Matusik <[email protected]> wrote:
Hi Peter and Mark,
I tried it with and without the timestamp bit, and I get the same behavior. Essentially, it takes about 10-15 s for the image to be updated in ImageJ. I'm attaching a screenshot of my URLDriver.adl screen as well as the image that I see on the web page and the image in ImageJ; you can see the two are not the same. My Acquire period is set to 1. The webcam should be outputting at 12fps in the web page.
Thanks!
On Tue, Aug 10, 2021 at 1:40 AM Heesterman, Peter J <[email protected]> wrote:
Hi Katie, Mark,
Could you try removing the ?timestamp=1628535368535 bit from the URL (leaving only http://10.0.1.50/mjpg/video.mjpg )?
The timestamp indicates a specific image frame, having a specific time stamp.
Cheers,
Peter.
Sent: 09 August 2021 20:01
Hi Mark and Peter,
Copying the image link and entering that into the URL setup screen does work; the new link looks like http://10.0.1.50/mjpg/video.mjpg?timestamp=1628535368535. When I pan the camera around, the image through the IOC does update, but very slowly relative to the camera updating in the web browser. Should I be expecting latency on the order of tens of seconds?
Thanks!
Katie
On Mon, Aug 9, 2021 at 10:41 AM Heesterman, Peter J <[email protected]> wrote:
Hi Katie,
I’m not familiar with that particular camera model.
I’ve been trying to locate one from http://www.insecam.org/en/bytype/Axis/, but the site only selects by manufacturer, and not by model type.
In the web browser view (I’m using Firefox for this), can you right click on the image and select ‘copy image link”.
Does this give a different URL?
If so, can you try that instead?
Many camera types emit a compound image which cannot be parsed by the ADURL module.
Cheers,
Peter.
From: Tech-talk <[email protected]> On Behalf Of Katie Matusik via Tech-talk
Sent: 09 August 2021 17:31
Hi Mark,
I'm using ADSupport R6-2-1 and I get the same error if %size=1 is removed from the url.
Thanks!
Katie
On Fri, Aug 6, 2021 at 8:16 PM Mark Rivers <[email protected]> wrote:
Hi Katie,
What version of ADSupport are you using?
What happens if you remove the &size=1 from the end of the URL?
Sent from my iPhone
On Aug 6, 2021, at 5:27 PM, Katie Matusik via Tech-talk <
Hi all,
I'm running epics base 3.15.9 with areaDetector R3-11 and using ADURL to try to grab images from an AXIS M5065 PTZ Network Camera. The URL of the image feed is
http://10.0.1.50/view/view.shtml?id=68&imagepath=%2Fmjpg%2Fvideo.mjpg&size=1 and I can see the live feed in the browser but I get an error message in the ADURL IOC that states "error reading URL="" No decode delegate for this image format (/tmp/gm48Qkon) reported by ../constitute.c:1534 (GmReadImage)". Any help is appreciated, thank you!
-Katie
https://static1.squarespace.com/static/56de1f4a2fe1318cf0aacc98/t/5d9e0fa57996446a078a8e1a/1570639781104/Logo_gmail_small.png?format=300w]
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee, you should not disseminate, distribute or copy this email. Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited
Katie Matusik
Systems Engineer
5750 Imhoff Drive, Suite I
Concord, CA 94520 USA
Office: 1 (925) 326 - 7926
Image removed by sender.
Katie Matusik
Systems Engineer
Katie Matusik
Systems Engineer
Katie Matusik
Systems Engineer
ADURL with Axis PTZ network camera Katie Matusik via Tech-talk
Re: ADURL with Axis PTZ network camera Mark Rivers via Tech-talk
Re: ADURL with Axis PTZ network camera Katie Matusik via Tech-talk
RE: ADURL with Axis PTZ network camera Heesterman, Peter J via Tech-talk
Prev: Re: ADURL with Axis PTZ network camera Katie Matusik via Tech-talk
Next: RE: Getting started talking to a device Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: RE: ADURL with Axis PTZ network camera Heesterman, Peter J via Tech-talk
