1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: exampleCPP Makefile questions
From: "Wang, Andrew via Tech-talk" <tech-talk at aps.anl.gov>
To: EPICS tech-talk <tech-talk at aps.anl.gov>
Date: Mon, 16 Aug 2021 21:00:44 +0000
All,
I am a bit stumped trying to get exampleCPP built for EPICS 7. Within the documentation, it says that the following need to be done.
make requires:
    A proper RELEASE.local is present one directory level above exampleCPP.
    Either ExampleRELEASE.local or MasterRELEASE.local is used.
ExampleRELEASE.local is used to build via an official EPICS 7 release.
MasterRELEASE.local is used to build via modules that have been cloned from github.
In either case the file chosen is copied to configure, renamed, and edited. For example:
cp ExampleRELEASE.local configure/RELEASE.local
gedit configure/RELEASE.local   // change EPICS7_DIR and possibly EPICS_BASE
The definition of EPICS7_DIR must be changed to the location where You installed and built a version of EPICS7.
I am not quite sure what this all entails. Some insight would be greatly appreciated.
Andy
Prev: Question about retrieve history data in archiver appliance lzfneu via Tech-talk
Next: phoebus display builder Vishnu Patel via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Prev: Re: RE: Question about retrieve history data in archiver appliance lzfneu at live.com via Tech-talk
ANJ, 23 Aug 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
