>> I intend to retrieve history data of some PV without running the IOC (offline), is it possible to implement that in archiver appliance.
Yes; this should be just fine.
>> I have no idea how to retrieve the history data of some PV without running the IOC
You should not have to do anything at all. Please check the use guide at https://slacmshankar.github.io/epicsarchiver_docs/userguide.html. For debugging, I usually find
it simpler to start using something like curl to see what's going in. You can construct a retrieval URL and then use curl to retrieve the data using a .txt mime type.
Hope that helps.
Murali
- Re: Question about retrieve history data in archiver appliance neu lzf via Tech-talk
phoebus display builder Vishnu Patel via Tech-talk
RE: IOC PVA on mTCA CPU requires environment variables to be set Meeus Kris via Tech-talk
<2021>
RE: Question about retrieve history data in archiver appliance Manoussakis, Adamandios via Tech-talk
<2021>
ANJ, 23 Aug 2021 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
