1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Trouble with macro substitutions
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: "Leblanc, Gregory" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 23 Aug 2021 16:43:04 +0000
Hi Greg,
On Aug 23, 2021, at 10:24 AM, Leblanc, Gregory via Tech-talk <[email protected]> wrote:
I’m having some trouble getting this substitution magic to work in my .db files.  I think that when I run ‘make’ I should get some .db files, which should have all of the $(XxX) stuff replaced, based on the contents of the .substitutions file, as long as the filenames match.  However, I’m getting some things replaced, and others not.  For example, I have the following in Watlow_PM_General.template:
        field(INPA,     "$(s):$(ta):$(ss):$(mod):ControlMode$(ch) CP")
And this in Watlow_PM_General.substitutions:
file Watlow_PM_General.template
pattern {  s, ta,      ss, mod, ch}
        {   , SE,  Watlow,   1,  1}
But when I compile, I get things like this in Watlow_PM_General.db:
        field(INPA,     "SE:Watlow:1:1:ControlMode$(ch) CP")
I haven’t been able to figure out why the ch macro is the only one not getting replaced.  Full source is at: https://github.com/gregoryleblanc/CsHeater
Well the obvious explanation is that the empty value intended for your $(s) macro in the substitutions file is being ignored — you have actually found a bug in our msi tool.
If it were setting $(s) to an empty string the PV name should begin with a colon character ‘:’ in the expanded version but it doesn’t — is that what you want to happen? For a workaround if you want $(s) to be empty you can do that by using an empty pair of double-quotes instead, I have just tried that and it works.
HTH,
- Andrew
Complexity comes for free, simplicity you have to work for.
Re: Trouble with macro substitutions Johnson, Andrew N. via Tech-talk
Trouble with macro substitutions Leblanc, Gregory via Tech-talk
Prev: Re: [EXTERNAL] Trouble with macro substitutions Hartman, Steven via Tech-talk
Next: Re: Trouble with macro substitutions Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
