1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Watlow_PM communication
To: "Leblanc, Gregory" <[email protected]>
Date: Wed, 25 Aug 2021 02:37:00 +0000
Hi Greg,
You need to keep in mind that the data types specified in command like this:
drvModbusAsynConfigure("watlow_AI_Num_1.1", "watlow1", 0, 4, 360, 62, 7, 2000, "watlow1");
can be overridden in the .template file with lines like this:
field(INP, "@asyn(watlow_AI_Num_1.$(mod),$(Ain=0),2000)FLOAT32_BE")
So the  data type in the drvModbusAsynConfigure is just a default and may not be used at all.
Sent from my iPhone
On Aug 24, 2021, at 5:24 PM, Leblanc, Gregory via Tech-talk <[email protected]> wrote:
Hi folks!
This question is probably specific to Gary, but I’m sending it to the list, because the information will hopefully be helpful to the next person who tries this.
Also, apologies for the lengthy email, but I’m trying to make sure all the information is included.
I’m trying to understand how the modbus read functions are designed.  I see following line in your st.cmd [1]:
which is reading 62 bytes starting at modbus address 360, and assume that they are type INT32_BE
2 lines later it says:
drvModbusAsynConfigure("watlow_AI_Enum_1.1", "watlow1", 0, 4, 362, 82, 6, 2000, "watlow1");
Which says read 82 bytes starting at address 362, and assume that they are type INT32_LE_BS [2]
I mapped the information from the manual, and put it in a file at:
https://github.com/gregoryleblanc/CsHeater/blob/main/AnalogInput.md
I’m guessing that the num line is reading in floats, and the enum line is reading in the same data, but reading the uint values, and there is something wonky about the byte order that you can’t read them into the same space.
Based on what I’ve gleaned, I’ve pared things down to a small config.  I’m not seeing any errors when I run st.cmd, and inside my ioc I see:
epics> dbl
:SE:Watlow:1:ControlModeActive1
:SE:Watlow:1:AutotuneStatus1
:SE:Watlow:1:ControlModeActive2
:SE:Watlow:1:AutotuneStatus2
:SE:Watlow:1:HeatPower1
:SE:Watlow:1:CoolPower1
:SE:Watlow:1:ProcessValue1
:SE:Watlow:1:ActiveSV1
:SE:Watlow:1:HeatPower2
:SE:Watlow:1:CoolPower2
:SE:Watlow:1:ProcessValue2
:SE:Watlow:1:ActiveSV2
Next, I tried grabbing ProcessValue 1 and 2:
$ caget :SE:Watlow:1:ProcessValue1 :SE:Watlow:1:ProcessValue2
:SE:Watlow:1:ProcessValue1     3.59505e-06
:SE:Watlow:1:ProcessValue2     0
Which doesn’t seem to match up at all with what I see on the controller:
https://www.flickr.com/gp/gregoryleblanc/gD9270
https://www.flickr.com/gp/gregoryleblanc/2TRm59
I’m not sure where to go from here.
     Greg
P.S. I’m hoping to map out the other data read blocks later in the week.
P.P.S. I have a patch to replace the numerical datatypes in your st.cmd with more descriptive strings.  Should I submit a pull request?
1: https://github.com/tauferg/Watlow-PM/blob/ea5096bf72f29eb42e3f2c2f5ee1a12ceb089863/Watlow_PM862FJ-3LEJAA_IOC/st.cmd.ModbusAddresses%20Only#L27
2: Little-endian byte swapped?  Somehow there’s got to be a tie between PDPs and Modbus, and I’m a bit scared.
Gregory Leblanc
Accelerator Engineer
Edwards Accelerator Lab - Ohio University
123 University Terrace
Athens, OH 45701
[email protected]<mailto:[email protected]>
M: (401) 52-OUAL1 or (401) 526-8251
RE: Watlow_PM communication Taufer, Gary via Tech-talk
Watlow_PM communication Leblanc, Gregory via Tech-talk
Prev: Watlow_PM communication Leblanc, Gregory via Tech-talk
Next: Re: CA Gateway converts int/float value to hex andrej.manojlovic--- via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: RE: Watlow_PM communication Taufer, Gary via Tech-talk
