1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: EPICS sequencer web page redirect problems
From: Kevin Peterson via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 26 Aug 2021 14:47:19 -0500
Thanks Andrew!  I didn't notice I was using a non-https link.
Kevin
On 8/25/21 7:47 PM, Johnson, Andrew N. wrote:
The APS “Common Support Modules" page at https://epics.anl.gov/modules/common.php <https://epics.anl.gov/modules/common.php> also pointed to the same address, but those links should be to https://www-csr.bessy.de/control/SoftDist/sequencer/ <https://www-csr.bessy.de/control/SoftDist/sequencer/> which works for me (just change http: into https:).
It appears that the web-server's http redirector isn’t actually pointing to the https web-server, resulting in infinite loops.
I just fixed the http: links on the APS EPICS website, including the one above.
- Andrew
EPICS sequencer web page redirect problems Kevin Peterson via Tech-talk
Re: EPICS sequencer web page redirect problems Johnson, Andrew N. via Tech-talk
Prev: RE: LIB_LIBS getting ignored Jones, Edward (CODAS&IT) via Tech-talk
Next: Re: LIB_LIBS getting ignored Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: EPICS sequencer web page redirect problems Johnson, Andrew N. via Tech-talk
Next: Download prblem for sequenzer Jörn Dreyer via Tech-talk
