1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: problems about epid
To: 岳宗仰 <[email protected]>
Date: Wed, 8 Sep 2021 12:02:14 +0000
Hi Zongyang,
You are getting this error right after iocInit():
PV: prj:epid1:outpv scanAdd: I/O Intr not valid (no DSET)
That is a known bug: https://github.com/epics-modules/optics/issues/10
The sseq record (and probably the swait record) does not support SCAN=I/O Intr.  I suggest you delete all of the lines like the following in fb_epid.db
(https://github.com/epics-modules/optics/blame/master/opticsApp/Db/fb_epid.db):
field(SCAN, "I/O Intr")
I don't understand how this database ever worked, but perhaps older versions of EPICS base did not catch this error.
From: Tech-talk <[email protected]> on behalf of 岳宗仰 via Tech-talk <[email protected]>
Sent: Wednesday, September 8, 2021 2:34 AM
To: [email protected]
Subject: problems about epid
Hello, all
I am learning to EPID record.
Following this guide, I meet some trouble
https://epics.anl.gov/bcda/synApps/optics/fb_epid/simulator.html
My iocInit shell as follow:
< envPaths
epicsEnvSet("IOC","iocepid_test")
epicsEnvSet("TOP","/home/yuezy/epid_test")
epicsEnvSet("EPICS_BASE","/opt/epics/base")
epicsEnvSet("SUPPORT","/opt/epics/support")
epicsEnvSet("OPTICS","/opt/epics/support/optics")
epicsEnvSet("STD","/opt/epics/support/std")
epicsEnvSet("asyn","/opt/epics/support/asyn")
epicsEnvSet("calc","/opt/epics/support/calc")
epicsEnvSet("SNCSEQ","/opt/epics/support/seq")
epicsEnvSet("busy","/opt/epics/support/busy")
epicsEnvSet("AUTOSAVE","/opt/epics/support/autosave")
epicsEnvSet("DEVIOCSTATS","/opt/epics/support/iocStats")
cd "/home/yuezy/epid_test"
dbLoadDatabase "dbd/epid_test.dbd"
epid_test_registerRecordDeviceDriver pdbbase
## Load record instances
dbLoadRecords("db/fb_epid.db","P=prj:epid1,IN=prj:epid1:sim.VAL,OUT=prj:epid1:sim.D,MODE=PID,CALC=A,PERMIT1="prj:epid1:on.VAL",PERMIT2="",PERMIT3="",PERMIT4=""")
iocInit
Starting iocInit
## EPICS R7.0.3.1
## EPICS Base built Jul 21 2021
recDynLinkOut: waiting for CA context
recDynLinkOut: got CA context
## Start any sequence programs
#seq sncxxx,"user=yuezy"
epics>
The Proportional and integral terms have values, but OVAL is always 0
My test result as follow
[yuezy@localhost epid_test]$ caget prj:epid1.P
prj:epid1.P                    9.99
[yuezy@localhost epid_test]$ caget prj:epid1.I
prj:epid1.I                    100
[yuezy@localhost epid_test]$ caget prj:epid1.OVAL
prj:epid1.OVAL                 0
Any suggestions or comments would be appreciated.
Best regards!
Zongyang yue
problems about epid 岳宗仰 via Tech-talk
Prev: European XFEL job ads: two Control Software Engineers (f/m/d) Steffen Hauf via Tech-talk
Next: Motor record support for Prevac SMCD14 stepper motor controller Ovsyannikov, Ruslan via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: problems about epid 岳宗仰 via Tech-talk
Next: European XFEL job ads: two Control Software Engineers (f/m/d) Steffen Hauf via Tech-talk
