1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Cannot build StreamDevice on Windows 64bit
From: "Zimoch Dirk \(PSI\) via Tech-talk" <[email protected]>
Date: Fri, 10 Sep 2021 07:46:49 +0000
On Thu, 2021-09-09 at 13:02 +0000, Freddie Akeroyd - STFC UKRI via Tech-talk wrote:
> If you look at that place, there's a hint:
> > #if defined(vxWorks) || defined(_WIN32) || defined(__rtems__)
> > // These systems have no strncasecmp
> > static int strncasecmp(const char *s1, const char *s2, size_t n)
Does anyone know the situation in RTEMS 5?
If RTEMS 5 has strncasecmp, how to branch correctly?
Re: Cannot build StreamDevice on Windows 64bit Johnson, Andrew N. via Tech-talk
Re: Cannot build StreamDevice on Windows 64bit Heinz Junkes via Tech-talk
Cannot build StreamDevice on Windows 64bit Lehmeyer, Johannes via Tech-talk
Re: Cannot build StreamDevice on Windows 64bit Ralph Lange via Tech-talk
RE: Cannot build StreamDevice on Windows 64bit Freddie Akeroyd - STFC UKRI via Tech-talk
Prev: Re: Cannot build StreamDevice on Windows 64bit Zimoch Dirk (PSI) via Tech-talk
Next: Re: Windows: Problem building EPICS base, using MSYS2 & mingw Luka Krmpotic via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: Re: Cannot build StreamDevice on Windows 64bit Johnson, Andrew N. via Tech-talk
