1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: NDPluginPva - PV not appearing on network
From: "Warrick, Edmund \(DLSLtd, RAL, LSCI\) via Tech-talk" <tech-talk at aps.anl.gov>
To: "tech-talk at aps.anl.gov" <tech-talk at aps.anl.gov>
Date: Tue, 14 Sep 2021 16:04:20 +0000
I’m trying to use the NDPluginPva plugin from ADCore to support a live viewer application for one of our beamline detectors. On one of my detectors, I seem to see the EPICS v4 PV consistently fail to appear on the network.
Using ADCore 3-8, PVAccess 7-0-0, on RHEL7.9
Relevant parts of my ioc startup script:
# NDPvaConfigure(portName, queueSize, blockingCallbacks, NDArrayPort, NDArrayAddr, pvName, maxBuffers, maxMemory, priority, stackSize)
NDPvaConfigure("EXCBR.pva", 16, 0, "EXCBR.CAM", 0, BL14I-EA-EXCBR-02:PVA:ARRAY, 0, 0, 0, 0)
startPVAServer
No error messages produced, and no alarm state shown by any of the v3 PVs in the plugin – but a pvget to the PV returned by PvName_RBV consistently times out. pvlist shows the detector server as hosting a pvaserver instance, but pvlist <host ip>:<port> to list the hosted PVs also times out.
I suspect some sort of race condition – by stripping back the IOC, removing everything but the PVA plugin and a simdetector instance, I can get it to successfully start serving the PV on startup some of the time, although sometimes it still fails to appear. When using the full detector driver IOC, it always fails.
Other ADCore IOCs on the same network using NDPluginPva respond to pvget requests as expected, and running up one of these IOCs temporarily on the same detector server also results in its PVA PV appearing.
I’d appreciate any assistance you can suggest with debugging this. I’m happy to provide any further diagnostic information that may help.
Ed Warrick
Senior Software Systems Engineer
Diamond Light Source
RE: NDPluginPva - PV not appearing on network Mark Rivers via Tech-talk
Prev: Re: Download prblem for sequenzer Ben Franksen via Tech-talk
Next: RE: NDPluginPva - PV not appearing on network Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Prev: RE: SynApps sscan record: timestamp issue for BUSY DATA and EXSC fields; causing problem archiving with Phoebus Archive engine Mark Rivers via Tech-talk
ANJ, 15 Sep 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
