1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: crash in CAS-event (high load?)
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Till Straumann <[email protected]>
Date: Wed, 22 Sep 2021 09:36:27 -0700
On 9/22/21 12:40 AM, Till Straumann wrote:
> Second that. I don't know if you are using run-time linking in which case you would have
> to translate the addresses before decoding them.
> You often also get valuable info from the register contents by correlating them
> with variables (disassemble the code around the fault location; sometimes
> you can find NULL or otherwise fishy pointers...)
Heinz followed up off-list.  It looks like this was the symptom of an issue with epicsEventTrigger()
for RTEMS 5 using POSIX functions which aren't safe for ISRs.
https://github.com/epics-base/epics-base/issues/202
> HTH
> - Till
> On 9/21/21 5:30 PM, Michael Davidsaver via Tech-talk wrote:
>> On 9/21/21 3:03 AM, Heinz Junkes via Tech-talk wrote:
>>> I don't know the best way to resolve the problem (debug, how?).
>>> Setting CASDEBUG outputs too much and I can not cope with this.
>> One place to start is decoding the stack trace using the addr2line utility.
>>> Stack Trace:
>>>    IP: 0x00230314, LR: 0x0022a680
>>> --^ 0x0022a67c--^ 0x0014ceb0--^ 0x0014d0ec--^ 0x0014d144--^ 0x00149df8
>>> --^ 0x00142e50--^ 0x001217c0--^ 0x0011a704--^ 0x00231b64--^ 0x0022b0ec
>>> --^ 0x002272c4fatal source: RTEMS_FATAL_SOURCE_EXCEPTION
>> Run:
>>> powerpc-rtems5-addr2line -e ./myexe 0x00230314 0x0022a680 0x0022a67c \
>>>   0x0014ceb0 0x0014d0ec 0x0014d144 0x00149df8 0x00142e50 0x001217c0 \
>>>   0x0011a704 0x00231b64 0x0022b0ec
crash in CAS-event (high load?) Heinz Junkes via Tech-talk
Re: crash in CAS-event (high load?) Michael Davidsaver via Tech-talk
Re: crash in CAS-event (high load?) Till Straumann via Tech-talk
Prev: Re: Quartz crystal microbalance readout SQC-310c device support Yendell, Gary (DLSLtd, RAL, LSCI) via Tech-talk
Next: Ava in caQtDM Mezger Anton Christian (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: crash in CAS-event (high load?) Till Straumann via Tech-talk
Next: modbusTCP liuxiaomin via Tech-talk
