1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Is it possible to switch to different camera for ADAravis without launching multiple IOC or restart the same IOC with different script?
From: "Liu, Wanming via Tech-talk" <[email protected]>
To: "Engbretson, Mark S." <[email protected]>
Date: Mon, 27 Sep 2021 15:20:52 +0000
Hi Mark,
Thanks for the comments.
Now I see what was missing, a call to asynSetTraceIOMask after switch the camera.
Wanming
Sent: Monday, September 27, 2021 10:10 AM
To: Liu, Wanming <[email protected]>
Cc: [email protected]
I would think that what one would do is something similar to this.
# The port name for the detector
epicsEnvSet("PORT1",   "ARV1")
# aravisConfig(const char *portName, const char *cameraName, int enableCaching, size_t maxMemory, int priority, int stackSize)
aravisConfig("$(PORT1)", "$(CAMERA_NAME1)", $(ENABLE_CACHING), 0, 0, 0)
asynSetTraceIOMask($(PORT1), 0, 2)
epicsEnvSet("PORT2",   "ARV2")
aravisConfig("$(PORT2)", "$(CAMERA_NAME2)", $(ENABLE_CACHING), 0, 0, 0)
asynSetTraceIOMask($(PORT2), 0, 2)
epicsEnvSet("PORT3",   "ARV3")
aravisConfig("$(PORT3)", "$(CAMERA_NAME3)", $(ENABLE_CACHING), 0, 0, 0)
asynSetTraceIOMask($(PORT3), 0, 2)
and install all the standard support and plugins for each one, and just flip the PV’s to whatever hardware that you are interested in. No?
That is how Mark Rivers does multiple ADSimDetectors.
From: Tech-talk <[email protected]> On Behalf Of Liu, Wanming via Tech-talk
Sent: Monday, September 27, 2021 9:55 AM
To: [email protected]
Subject: Is it possible to switch to different camera for ADAravis without launching multiple IOC or restart the same IOC with different script?
We have multiple PointGrey BlkFly cameras of the same model on our beamline.  We only take image data from one camera at any time.
We could launch multiple ADAravis IOCs with one for each camera and switching PV names in GUI/OPI.  But is it possible to launch just one IOC and switch to different cameras as needed?
I added stringout device support to ADAravis and created a record to change the camera name.  So far, It seems like I can get the IOC connect to a different camera with pvput.  But a lots of errors message will popup when I try to use the camera.
Here is what I did when the camera name stringout record is being processed.
I added a member function ChangeCamera to ADAravis as
void ADAravis::ChangeCamera(const char *cameraName)
    delete this->cameraName;
    this->cameraName = epicsStrDup(cameraName);
//    printf("%s\n",this->cameraName);
    connectToCamera();
When the CameraName record is processed, it will call this CahngeCamera function.
From the printout of IOC shell as response to the ChangeCamera call,
CameraName 192.168.2.98
ADAravis: Looking for camera '192.168.2.98'...
2021/09/27 09:13:01.493 13ARV1:cam1:ARConnectCamera devAsynInt32::processCallbackOutput process write error
ADAravis: Your tick frequency is 125000000
So your timestamp resolution is 8.000000 ns
It looks like that the camera was successfully switched in  aravis, but asyn driver seems to have some troubles.
When I tried to use the camera, lots of error or warning like the following pops up which seems that the other part of the IOC is still using the old camera instance which is no longer exist.
(process:2490): GLib-GObject-WARNING **: 09:20:01.768: invalid uninstantiatable type '<invalid>' in cast to 'ArvGcFeatureNode'
** (process:2490): CRITICAL **: 09:20:01.769: arv_gc_feature_node_is_available: assertion 'ARV_IS_GC_FEATURE_NODE (gc_feature_node)' failed
(process:2490): GLib-GObject-WARNING **: 09:20:01.769: invalid unclassed pointer in cast to 'ArvGcFeatureNode'
So it will take more than just ADAravis::ConnectToCamera() to make the switching work.  But I don’t know what to add to ChangeCamera yet.
Any comments and suggestions will be greatly appreciated.
Wanming Liu
L120B, Bldg 360
HEP,ANL
Re: Is it possible to switch to different camera for ADAravis without launching multiple IOC or restart the same IOC with different script? Mark Rivers via Tech-talk
Is it possible to switch to different camera for ADAravis without launching multiple IOC or restart the same IOC with different script? Liu, Wanming via Tech-talk
RE: Is it possible to switch to different camera for ADAravis without launching multiple IOC or restart the same IOC with different script? Engbretson, Mark S. via Tech-talk
Prev: RE: Is it possible to switch to different camera for ADAravis without launching multiple IOC or restart the same IOC with different script? Engbretson, Mark S. via Tech-talk
Next: Re: Is it possible to switch to different camera for ADAravis without launching multiple IOC or restart the same IOC with different script? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
