1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Monitoring with deadband defined
From: "a-ch.mezger--- via Tech-talk" <[email protected]>
To: [email protected]
Date: Fri, 1 Oct 2021 12:24:00 +0200
When in epics7 a channel or pv is monitored with a deadband  (perhaps also in 3.15), then a value will only be given when the value exceeds the deadband. This is the expected behaviour. However in case of a display manager, no value will be displayed when monitoring values until the deadband is exceeded. This seems to me a rather special behaviour for existing display managers that rely on monitoring the values.
Perhaps I am wrong, but perhaps a first value should be se
Prev: RE: Is it possible to switch to different camera for ADAravis without launching multiple IOC or restart the same IOC with different script? Liu, Wanming via Tech-talk
Next: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
