1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: High Voltage PS with RS-232 serial port
To: Hasan SANSAR <[email protected]>
Cc: [email protected]
Date: Fri, 1 Oct 2021 09:08:38 -0700
What does
ls -l /dev/ttyS*
show?
Perhaps this is just a permission issue?
On Oct 1, 2021, at 4:33 AM, Hasan SANSAR via Tech-talk <[email protected]> wrote:
Hi all,
We were using Glassman's HVPS with RS-232 serial port connection diretcly on CentOS 7.4 on MOXA DA-682A. And I updated CentOS to 7.9. after that MOXA PC started to not recognizing RS-232 serial connection. So, we are using High Voltage PS with TCP/IP converter  for temporary reason.
I'm getting same error in here at tech-talk discussion:
https://epics.anl.gov/tech-talk/2013/msg01079.php
> drvAsynSerialPortConfigure("L0","/dev/ttyS0",0,0,0)
> asynSetOption("L0", -1, "baud", "9600")
> setOption failed tcsetattr failed: Input/output error
How can I solve this problem and how can I connect to this device over RS-232 port again?
Eric Norum
High Voltage PS with RS-232 serial port Hasan SANSAR via Tech-talk
Prev: Re: channel and pv deadband Mezger Anton Christian (PSI) via Tech-talk
Next: Re: High Voltage PS with RS-232 serial port Eric Norum via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: High Voltage PS with RS-232 serial port Hasan SANSAR via Tech-talk
