thanks, the camera is already here. "old stuff". are all products from FLIR supported ? - W
Am 06.10.2021 um 13:44 schrieb Mark
Rivers:
Hi William, There is no mention on their Web site that the camera is GenICam compliant. If it were then you could use ADAravis on Linux. It appears that their software library only works on Windows. Do you already have this camera, and if so it there any reason it could not be replaced with another one? You could replace it for less than $400 with a much better performance FLIR camera. That is much less than the cost of writing an EPICS driver for an unsupported camera. Mark ________________________________ From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of William Kirstaedter via Tech-talk <tech-talk at aps.anl.gov> Sent: Wednesday, October 6, 2021 6:22 AM To: EPICS tech-talk Subject: Imaging Source USB Camera Hi, just wanted to check; has anyone already integrated the following camera into EPICS ? "Imaging Source DMK 41AU02" its a simple greyscale USB 2.0 Camera. there is a C library available: https://www.theimagingsource.com/products/industrial-cameras/usb-2.0-monochrome/dmk41au02/ any thoughts about this thing? -- [cid:[email protected]] William Kirstaedter (PP&B) Fritz-Haber-Institut der MPG Faradayweg 4-6 14195 Berlin Tel: 030 8413 5405 Mail: kirstaedter at fhi-berlin.mpg.de<mailto:kirstaedter at fhi-berlin.mpg.de>
ANJ, 06 Oct 2021 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
