1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: pvaPy: PvObject - odict_keys not subscriptable issue
From: "Veseli, Sinisa via Tech-talk" <[email protected]>
To: Kuldeep Joshi <[email protected]>
Date: Wed, 6 Oct 2021 22:27:46 +0000
I have not used pcaspy myself, but there are pip packages for python3.
As far as your second question, I am no phoebus expert, but it seems like the intent of the other widgets on the page was to show how to display arbitrary structures in addition to displaying tables.
In any case, in my environment the server.py example did not quite work as expected for python with numpy installed (see fixes below).
Hope this helps,
Sinisa
bluegill2> git diff ./app/display/model/src/main/resources/examples/table/server.py
diff --git a/app/display/model/src/main/resources/examples/table/server.py b/app/display/model/src/main/resources/examples/ta
index d8e6d17..791040e 100644
--- a/app/display/model/src/main/resources/examples/table/server.py
+++ b/app/display/model/src/main/resources/examples/table/server.py
@@ -12,7 +12,7 @@ print("")
 #nt_table: complies with NTTable Normative Type
 #note: Unless the PvObject's 'values' field is created with an ordered dict, the ordering will be lost.
 ntTablePV = PvObject( {'labels' : [STRING],
-                       'value' : OrderedDict([('id_field', [INT]), ('name_field', [STRING]), ('description_field', [STRING])
+                       'value' : dict(OrderedDict([('id_field', [INT]), ('name_field', [STRING]), ('description_field', [STR
                        'epics:nt/NTTable:1.0')
 ntTablePV['labels'] = ['ID', 'Name', 'Description']
 #every field under "value" must have the same length (number of elements)
@@ -23,9 +23,10 @@ ntTablePV.setStructure({'id_field': [1, 2, 3, 4],
 #table: a table-like pv that contains a "value" which is a structure
 #tablePV is not an NTTable because "dingus" is a structure, not a scalar type
 #Only the "value" field is displayed; the meta-data field is ignored
-dingus_types = OrderedDict([('Name', [STRING]), ('Quality', [DOUBLE])])
-value_types = OrderedDict([('OK', [BOOLEAN]), ('Dingus', dingus_types)])
+dingus_types = dict(OrderedDict([('Name', [STRING]), ('Quality', [DOUBLE])]))
+value_types = dict(OrderedDict([('OK', [BOOLEAN]), ('Dingus', dingus_types)]))
 tablePV = PvObject({'meta_data' : STRING, 'value' : value_types})
+tablePV.useNumPyArrays = False
 tablePV['meta_data'] = 'Some example meta-data stuff'
 dingus = {'Name' : ["Thing1", "Thing2", "Thing3"], 'Quality' : [90, 50, 75]}
Siniša Veseli
Scientific Software Engineering & Data Management
Advanced Photon Source
Argonne National Laboratory
(630)252-9182
Sent: Wednesday, October 6, 2021 12:53 AM
To: Veseli, Sinisa <[email protected]>
Cc: [email protected] <[email protected]>
Hello,
Thank you the code with your suggested modification is working.
I am unable to execute ca_table_server.py located in the table folder (of Phoebus Examples)  with Python3. Can I use the pcaspy lib for python3
It works fine with python2.7
I tried another Phoebus demo code server.py at this path "Display Builder/table" located at
Here I have incorporated the dict() call as per your suggestion. Table is visible only for the first table widget.
For the remaining widgets I am seeing structure for the pva. I guess the structure is not proper.
pl find the snap attached.
Kuldeep
On Tue, Oct 5, 2021 at 2:08 PM Veseli, Sinisa <[email protected]> wrote:
For python3 it looks like phoebus example needs to be modified a bit. Could you please try these changes?
bluegill2> git diff app/display/model/src/main/resources/examples/table_server/server.py
diff --git a/app/display/model/src/main/resources/examples/table_server/server.py b/app/display/model/src/main/resources/exam
index 54135d7..1e1a579 100644
--- a/app/display/model/src/main/resources/examples/table_server/server.py
+++ b/app/display/model/src/main/resources/examples/table_server/server.py
@@ -54,7 +54,7 @@ def updateValue(pv):
 # create PVs
 tableStructDict = {'labels' : [STRING],
-                    'value' : OrderedDict([('id', [UINT]), ('name', [STRING]), ('title', [STRING])])}
+                    'value' : dict(OrderedDict([('id', [UINT]), ('name', [STRING]), ('title', [STRING])]))}
 tablePV = PvObject(tableStructDict, "epics:nt/NTTable:1.0")
 tablePV['labels'] = ['ID', 'Name', 'Title']
 namePV = PvString('')
@@ -63,5 +63,8 @@ namePV = PvString('')
 server = PvaServer('table', tablePV)
 server.addRecord('name', namePV, updateValue)
-raw_input("\nEnter anything to quit\n")
+try:
+    raw_input("\nEnter anything to quit\n")
+except NameError as ex:
+    input("\nEnter anything to quit\n")
The above should work on both python2 and python3.
Please let me know if you have any issues.
Sinisa
Siniša Veseli
(630)252-9182
From: Tech-talk <[email protected]> on behalf of Kuldeep Joshi via Tech-talk <[email protected]>
Sent: Tuesday, October 5, 2021 1:54 AM
To: [email protected] <[email protected]>
Subject: pvaPy: PvObject - odict_keys not subscriptable issue
Hello,
I was trying to execute a python script that is available with the phoebus example.
I am getting an "odict_keys object is not subscriptable" error.
I understand this is so for all python3.x versions. The code is getting executed on Python2.x versions
However I see that pvaPy supports python3.x. What am I doing wrong.
Kuldeep
The console output:
phoebus/example/Display Builder/table_server$ python server.py
server.py:34: SyntaxWarning: "is" with a literal. Did you mean "=="?
  if name is '':
Traceback (most recent call last):
  File "server.py", line 58, in <module>
TypeError: 'odict_keys' object is not subscriptable
pvaPy: PvObject - odict_keys not subscriptable issue Kuldeep Joshi via Tech-talk
Re: pvaPy: PvObject - odict_keys not subscriptable issue Veseli, Sinisa via Tech-talk
Re: pvaPy: PvObject - odict_keys not subscriptable issue Kuldeep Joshi via Tech-talk
Prev: RE: Backing up the ArchiverStores STS MTS LTS Epic Archiver Appliance Shankar, Murali via Tech-talk
Next: Re: Imaging Source USB Camera William Kirstaedter via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: pvaPy: PvObject - odict_keys not subscriptable issue Kuldeep Joshi via Tech-talk
Next: iocStats module on RTEMS-5 Ben Franksen via Tech-talk
