1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: Epics Archiver Appliance Storage Question
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: Abdalla Ahmad <[email protected]>, EPICS tech-talk <[email protected]>
Date: Tue, 12 Oct 2021 07:21:13 +0000
Thanks Abdalla, seems like it shouldn’t be too much trouble.  I have tried stopping the tomcat instances, making sure the environment variable is set correctly (I did see in the policies.py file where the paths are set).  I tried to restart the archiver appliance and also re-archived the pv (paused/deleted) but it still seems to be going to the old spot.  It looks like the file I am using is from Hans site-specific install where it was hardcoded the paths actually for sts/mts/lts.  I tried to just change the directory to see if it would work but still no success in getting the archiver to save the files in a different directory for sts.
Adam
Sent: Monday, October 11, 2021 11:43 PM
To: Manoussakis, Adamandios <[email protected]>; EPICS tech-talk <[email protected]>
Hi Adam
I think it should be easy by changing the macro variables, I think we did this before and it was working, just make sure that you have read/write permissions on the new locations otherwise all your PVs will remain in the “Appliance Assigned” state. For your 2nd question, STORAGE_TOP is optional, the three storage locations definitions are independent, it is not mandatory for the locations or mount points to share the same “STORAGE_TOP”, you can specify each store in the appropriate mount point in your setup.
If you have enough RAM on your server, it is best practice to setup the STS using a RAM disk (the tempfs filesystem), this will improve performance on data retrieval for recent periods.
Best Regards,
Abdalla Al-Dalleh
Control Engineer, SESAME
Phone: +962-788183296
Email: [email protected]
Sent: Tuesday, October 12, 2021 1:57 AM
To: EPICS tech-talk
Subject: Epics Archiver Appliance Storage Question
Hey All,
I am planning on changing where our STS MTS and LTS are stored.  Most likely will use STS MTS on the local SSD I have but wanted to move our LTS over to a NAS or some external storage.  Wanted to know if there are any pitfalls to setting this up or is at as easy as changing up these values in the archappl.conf?  Also was wondering about what STORAGE_TOP does if say my LONG_TERM_FOLDER does not share the same STORAGE_TOP directory for example?
ARCHAPPL_STORAGE_TOP="/arch"
ARCHAPPL_SHORT_TERM_FOLDER="/arch/sts/ArchiverStore"
ARCHAPPL_MEDIUM_TERM_FOLDER="/arch/mts/ArchiverStore"
ARCHAPPL_LONG_TERM_FOLDER="/Network/lts/StorageExample "
Adam
Re: Epics Archiver Appliance Storage Question Wilson, Andy (DLSLtd, RAL, LSCI) via Tech-talk
Epics Archiver Appliance Storage Question Manoussakis, Adamandios via Tech-talk
RE: Epics Archiver Appliance Storage Question Abdalla Ahmad via Tech-talk
Prev: How to access PSI Elog data from other web clients Wang, Lin via Tech-talk
Next: Re: Epics Archiver Appliance Storage Question Wilson, Andy (DLSLtd, RAL, LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: Epics Archiver Appliance Storage Question Abdalla Ahmad via Tech-talk
