Hi all, I use centos 8(64), base7.0.6.1,asyn from the github( https://github.com/epics-modules ) When I make tha asyn module, I met the question. make[2]: Entering directory '/home/liangyx/synApps/support/asyn-master/asyn/O.linux-x86_64' cp ../vxi11/vxi11intr.rpcl . rpcgen vxi11intr.rpcl make[2]: rpcgen: Command not found cp ../vxi11/vxi11core.rpcl . rpcgen vxi11core.rpcl make[2]: rpcgen: Command not found make[2]: *** No rule to make target 'vxi11core_xdr.c', needed by 'vxi11core_xdr.o'. Stop. make[2]: Leaving directory '/home/liangyx/synApps/support/asyn-master/asyn/O.linux-x86_64' make[1]: *** [/home/liangyx/base-7.0.6.1/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2 make[1]: Leaving directory '/home/liangyx/synApps/support/asyn-master/asyn' make: *** [/home/liangyx/base-7.0.6.1/configure/RULES_DIRS:85: asyn.install] Error 2 I have tried "yum install glibc-utils and yum install glibc." Neither worked. How I could fix it? Thanks Liang
ANJ, 15 Oct 2021 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
