1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: motor module make error
From: Kevin Peterson via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>, 网易邮件中心 <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 21 Oct 2021 17:40:41 -0500
I've built motor-R7-2-2 against base-7.0.4.1 on RHEL8, but I haven't built anything against base-7.0.6.1 yet. I'll test that tomorrow.
Kevin
On 10/21/21 11:48, Johnson, Andrew N. wrote:
I suspect this build error may be due to the updated version of g++ that comes with CentOS-8/RHEL-8 which has stricter language rules than the Motor support was written for (Kevin — have you tried building Motor using RHEL-8 yet? I’d expect you to see exactly the same errors there).
Re: motor module make error Kevin Peterson via Tech-talk
motor module make error 网易邮件中心 via Tech-talk
Re: motor module make error Johnson, Andrew N. via Tech-talk
Prev: RE: Measurement Computing USB-1608G_2AO support Mark Rivers via Tech-talk
Next: Re: Measurement Computing USB-1608G_2AO support Dudley, David via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: motor module make error Johnson, Andrew N. via Tech-talk
Next: Re: motor module make error Kevin Peterson via Tech-talk
