1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: EPICs archiver appliance, exporting DESC field in the JSON
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: EPICS tech-talk <[email protected]>
Date: Fri, 29 Oct 2021 22:34:41 +0000
Hey All,
I am wondering why the getdataattime endpoint doesn’t seem to return some of the meta data type fields like DESC or EGU?  I tried to go into the policies.py file and add in some more fields to export but not sure I am doing it in the right spots.  These are the two parts in policies.py that I thought would need to be changed to handle the other fields.  Although I am still not sure why the getdataforpvs is able to export the meta data fields.
# Define a list of fields that will be archived as part of every PV.
# The data for these fields will included in the stream for the PV.
# We also make an assumption that the data type for these fields is the same as that of the .VAL field
def getFieldsArchivedAsPartOfStream():
                return ['HIHI','HIGH','LOW','LOLO','LOPR','HOPR','DRVH','DRVL'];
if "RTYP" not in pvInfoDict:
                                pvPolicyDict["archiveFields"]=archiveFields
                else:
                                pvRTYP=pvInfoDict["RTYP"]
                                if pvRTYP=="ai":
                                                archiveFields=['HIHI','HIGH','LOW','LOLO','LOPR','HOPR']
                                elif pvRTYP=="ao":
                                                archiveFields=['HIHI','HIGH','LOW','LOLO','LOPR','HOPR','DRVH','DRVL']
                                elif pvRTYP=="calc":
                                elif pvRTYP=="calcout":
                                elif pvRTYP=="longin":
                                elif pvRTYP=="longout":
                                elif pvRTYP=="dfanout":
                                elif pvRTYP=="sub":
                return pvPolicyDict
Prev: RE: Failed connection using e3-s7plc to Siemens S7-1500 Miklós Boros via Tech-talk
Next: RE: Does camonitor update when the record processes? Wang, Andrew via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: RE: Does camonitor update when the record processes? Wang, Andrew via Tech-talk
Next: Re: EPICs archiver appliance, exporting DESC field in the JSON Shankar, Murali via Tech-talk
