1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: archiver appliance start failed
To: tech-talk <[email protected]>
Date: Thu, 4 Nov 2021 16:23:48 +0800 (CST)
Hi all,
      I installed the archiver appliance using the instruction:  http://slacmshankar.github.io/epicsarchiver_docs/installguide.html
      the installation was good, but when I did: ./sampleStartup.sh start.
     Software: Centos 8(64),  Apache Tomcat/9.0.54, jdk 1.8.0_312
1)----------First -----------------
                 [iasf@localhost tomcat_instances]$ ./sampleStartup.sh start
                 ./sampleStartup.sh: line 9: /opt/local/setEPICSEnv.sh: No such file or directory
Then I uncomment the line, since (1) I could not found "setEPICSEnv.sh" file. (2)I have already set  EPICS_CA_ADDR_LIST=localhost, EPICS_CA_AUTO_ADDR_LIST=YES, EPICS_CA_MAX_ARRAY_BYTES=16384, JAVA_HOME, JRE_HOME,EPICS_HOST_ARCH=linux-x86_64,EPICS_BASE  in my own environment.
I do not know whether it was right.
2)---------------Second----------------( i did as "https://github.com/slacmshankar/epicsarchiverap/issues/41" said [ the LD_LIBRARY_PATH error], but nothing changed. )
Starting tomcat at location /home/iasf/EpicsAA/tomcat_instances/mgmt
Using 64 bit versions of libraries
~/EpicsAA/tomcat_instances/mgmt/logs ~/EpicsAA/tomcat_instances
Starting tomcat at location /home/iasf/EpicsAA/tomcat_instances/engine
~/EpicsAA/tomcat_instances/engine/logs ~/EpicsAA/tomcat_instances
Starting tomcat at location /home/iasf/EpicsAA/tomcat_instances/etl
~/EpicsAA/tomcat_instances/etl/logs ~/EpicsAA/tomcat_instances
Starting tomcat at location /home/iasf/EpicsAA/tomcat_instances/retrieval
~/EpicsAA/tomcat_instances/retrieval/logs ~/EpicsAA/tomcat_instances
It seems not good, and the  http://{MY_IP_address}:17665/mgmt/ui/index.html could not connect, it shows 404 code.
I check the firewall, it was stop.
What should I do it? why it did not start.
Cheers,
Liang
Prev: ArchiverAppliance LTS to S3-Storage Heinz Junkes via Tech-talk
Next: Archiver Appliance configuration questions Wilson, Andy (DLSLtd, RAL, LSCI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: RE: archiver appliance start failed Abdalla Ahmad via Tech-talk
