1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: css could not start since java version changed
To: tech-talk <[email protected]>
Date: Sat, 6 Nov 2021 16:48:48 +0800 (CST)
Hi all,
     Today I changed my jdk from 1.8.0 to 17.0.1.
     Then I changed and source the environment  of JAVA_HOME.
java version "17.0.1" 2021-10-19 LTS
Java(TM) SE Runtime Environment (build 17.0.1+12-LTS-39)
Java HotSpot(TM) 64-Bit Server VM (build 17.0.1+12-LTS-39, mixed mode, sharing)
     Now CSS could not be startup.
     I changed  the version number  in css.ini "-Dosgi.requiredJavaVersion=17.0.1", but not working.
     log file show that wht version was not changed.
---------------------------------log of CSS----------------------------------------
!SESSION 2021-11-02 16:28:57.514 -----------------------------------------------
eclipse.buildId=SNS_CSS
java.version=1.8.0_312     # i think the version was not modified. css still use the old one.
java.vendor=Red Hat, Inc.
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments:  -os linux -ws gtk -arch x86_64
---------------------------------End ---------------------------------------
     Could someone tell me how to fix it?
Cheers,
Liang
Prev: Re: IOC in Docker not responding to caget from another host Paduan Donadio, Marcio via Tech-talk
Next: Archiver Appliance sometimes stops archiving some PVs or loses points Wang, Lin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: nPoint motor driver Kevin Peterson via Tech-talk
