1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: EPICS support for the Omega Platinum Series PID Controllers
From: "Wlodek, Jakub via Tech-talk" <[email protected]>
To: "Sobhani, Bayan" <[email protected]>, "Saleh, Ibrahim" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 9 Nov 2021 19:42:53 +0000
Hi Alex, Ibrahim,
Thank you for the suggestion - I had seen the omega i series IOC, and was planning to use that as a base if the need for developing a driver arises. Looking through the i series manual it seems there are some similar commands to those used by the Pt series, but the protocols are not a 1-to-1 match, which likely means at least some development work will be required. Thank you for the links they will both come in helpful.
Best,
Jakub
Sent: Tuesday, November 9, 2021 12:46 PM
To: Saleh, Ibrahim <[email protected]>; Wlodek, Jakub <[email protected]>; [email protected] <[email protected]>
Subject: RE: EPICS support for the Omega Platinum Series PID Controllers
I am guessing the Omega Pt series communication is different from the Omega I series? Here is an internal link to the protocol file for the Omega I series IOC if you have not already seen it:
https://gitlab.nsls2.bnl.gov/EPS/omega_i_series/blob/master/protocols/omega-CNi32.proto
This should tell you whether or not they are similar.
Alex
From: Tech-talk <[email protected]> On Behalf Of Saleh, Ibrahim via Tech-talk
Sent: Tuesday, November 9, 2021 12:04 PM
To: Wlodek, Jakub <[email protected]>; [email protected]
Hello Jakob,
We use CNI3253-C24-DC for rack temperature control applications. We use simple StreamDevice commands to read temperature and write setpoints based on the following manual: omega_CNi16_communications.pdf (lbl.gov). Let me know if you want further information.
Ibrahim
From: Tech-talk <[email protected]> On Behalf Of Wlodek, Jakub via Tech-talk
Sent: Monday, November 8, 2021 4:57 PM
To: [email protected]
Subject: EPICS support for the Omega Platinum Series PID Controllers
Hello all,
Before I begin making plans to develop a new driver for this purpose, has anyone developed EPICS support for the Omega Platinum Series of PID controllers?
The specific model I am thinking of is the CN8PT-445, however, based on my preliminary research it seems that the communication protocols are shared between the models in the Platinum line:
If anyone has had a chance to work with one of these and develop an EPICS driver for it, please let me know!
Jakub
EPICS support for the Omega Platinum Series PID Controllers Wlodek, Jakub via Tech-talk
RE: EPICS support for the Omega Platinum Series PID Controllers Saleh, Ibrahim via Tech-talk
RE: EPICS support for the Omega Platinum Series PID Controllers Sobhani, Bayan via Tech-talk
Prev: RE: EPICS support for the Omega Platinum Series PID Controllers Sobhani, Bayan via Tech-talk
Next: Re: How to access PSI Elog data from other web clients Wang, Lin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: StreamDevice checksum methods Josh Fiddler via Tech-talk
