1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Subject: Re: Understanding Motor Record
From: Torsten Bögershausen via Tech-talk <tech-talk at aps.anl.gov>
To: Mark L Rivers <rivers at cars.uchicago.edu>
Cc: EPICS Tech Talk <tech-talk at aps.anl.gov>
Date: Tue, 16 Nov 2021 18:15:44 +0100
Hej Mark and Heinz,
If I command the motor to -10 mm,
and it runs into the limit switch at -2.970
The we see that .VAL stays at -10 mm, (where the motor should have gone)
and .RBV is -2.970 (where the motor is)
So the “correlation” is lost - on purpose.
Thats my understanding.
HTH
/Torsten
> On 16 Nov 2021, at 18:09, Mark L Rivers via Tech-talk <tech-talk at aps.anl.gov> wrote:
> Hi Heinz,
> It looks like you are using an encoder (UEIP=Yes), and your encoder readback (REP) is 0.  When the motor record hits a limit switch I believe it sets the DVAL to the readback value.
> Mark
> From: Tech-talk <tech-talk-bounces at aps.anl.gov> on behalf of Heinz Junkes via Tech-talk <tech-talk at aps.anl.gov>
> Sent: Tuesday, November 16, 2021 10:59 AM
> To: EPICS Tech Talk <tech-talk at aps.anl.gov>
> Subject: Understanding Motor Record
> I am having problems with Motor-Record right now.
> I am using Epics 7 and the latest MotorRecord
> (master: https://github.com/epics-modules/motor)
> When I reach a Limit - Switch, then there is no
> correlation between RMP and DVAL/VAL anymore?
> RMP : 1361 vs. DVAL: 0 and VAL : 0 ??
> I'm using the same hardware as I have for 10 years (Oms MAXv), only
> now I have Epics7 with the new motor-record in use.
> I also have the feeling that something with the conversion of the
> EGU and the direction etc. does not fit.
> But unfortunately can not specify yet because "somehow some is wrong”
> Danke Heinz
> > dbpr FHIFEL:M11PH,10
> ACCL: 1             ACKS: NO_ALARM      ACKT: YES           ADEL: 0
> ALST: 0             ASG :               ASP : PTR 0x0       ATHM: 0
> BACC: 1             BDST: 0             BKLNK: ELL 0 [0x0 .. 0x0]
> BKPT: 00            BVEL: 4.5           CARD: 0             CBAK: PTR 0x15f9bf8
> CDIR: 1             CNEN: Disable       DCOF: 0
> DESC: M1 Pinhole OMS_Z                  DHLM: 140           DIFF: 0
> DINP: CONSTANT      DIR : Pos           DISA: 0             DISP: 0
> DISS: NO_ALARM      DISV: 1             DLLM: -140          DLY : 0
> DMOV: 1             DOL : CONSTANT      DPVT: PTR 0x15f9c18 DRBV: 0
> DSET: PTR 0x462d34  DTYP: OMS MAXv      DVAL: 0             EGU : mm
> ERES: 1.171875e-04  EVNT:               FLNK: CONSTANT      FOF : 0
> FOFF: Frozen        FRAC: 1             HHSV: NO_ALARM      HIGH: 0
> HIHI: 0             HLM : 140           HLS : 1             HLSV: NO_ALARM
> HOMF: 0             HOMR: 0             HOPR: 0             HSV : NO_ALARM
> HVEL: 4.5           ICOF: 0             IGSET: 0            INIT:
> JAR : 7.5           JOGF: 0             JOGR: 0             JVEL: 4.5
> LCNT: 0             LDVL: 0             LLM : -140          LLS : 0
> LLSV: NO_ALARM      LOCK: NO            LOLO: 0             LOPR: 0
> LOW : 0             LRLV: 0             LRVL: 0             LSET: PTR 0x1548258
> LSPG: Go            LSV : NO_ALARM      LVAL: 0             LVIO: 0
> MDEL: 0             MIP : 0             MISS: 1
> MLIS: ELL 148 [0x2190a58 .. 0x177254c8] MLOK: 01 54 f4 10   MLST: 0
> MMAP: 0             MOVN: 0             MRES: 1.171875e-04  MSTA: 7
> NAME: FHIFEL:M11PH  NMAP: 0             NSEV: NO_ALARM      NSTA: NO_ALARM
> NTM : YES           NTMF: 2             OFF : 0             OMSL: supervisory
> OUT : VME_IO #C0 S2 @                   PACT: 0             PCOF: 0
> PHAS: 0             PINI: NO            POST:               PP  : 0
> PPN : PTR 0x0       PPNR: PTR 0x0       PREC: 3             PREM:
> PRIO: LOW           PROC: 0             PUTF: 0             RBV : 0
> RCNT: 0             RDBD: 0.1           RDBL: CONSTANT      RDES: PTR 0xcbd400
> RDIF: 0             REP : 0             RHLS: 1             RINP: CONSTANT
> RLLS: 0             RLNK: CONSTANT      RLV : 0             RMOD: Default
> RMP : 1361          RPRO: 0             RRBV: 0             RRES: 999.99
> RSET: PTR 0x462f4c  RSTM: NearZero      RTRY: 5             RVAL: 0
> RVEL: 0             S   : 5             SBAK: 3             SBAS: 3
> SCAN: Passive       SDIS: CONSTANT      SET : Use           SEVR: NO_ALARM
> SMAX: 12            SPDB: 0             SPMG: Go            SPVT: PTR 0x0
> SREV: 12800         SSET: 0             STAT: NO_ALARM      STOO: CONSTANT
> STOP: 0             STUP: OFF           SUSE: 0             SYNC: 0
> TDIR: 1             TIME: 2021-11-16 16:45:24.834573822     TPRO: 0
> TSE : 0             TSEL: CONSTANT      TWF : 0             TWR : 0
> TWV : 1             UDF : 0             UDFS: INVALID       UEIP: Yes
> UREV: 1.5           URIP: No            VAL : 0             VBAS: 4.5
> VELO: 7.5           VERS: 7.2           VMAX: 18            VOF : 0
Re: Understanding Motor Record Heinz Junkes via Tech-talk
Re: Understanding Motor Record Mark L Rivers via Tech-talk
Prev: Re: Understanding Motor Record Mark L Rivers via Tech-talk
Next: RE: Failed connection using e3-s7plc to Siemens S7-1500 Miklós Boros via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <20212022  2023  2024  2025
Next: Re: Understanding Motor Record Heinz Junkes via Tech-talk
ANJ, 16 Nov 2021 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions ·
