1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: ADEiger/Filewriter question
From: John Dobbins via Tech-talk <[email protected]>
To: Mark L Rivers <[email protected]>
Date: Sat, 20 Nov 2021 21:41:13 +0000
Mark,
Our solution was to change EIG500:EIG:FWNamePattern with each scan. (Is there a way to make this auto-increment?)
Also, FWAutoRemove = Yes should solve the problem?
I was just trying to understand where I might have gone astray, something I have a knack for.
John
Sent: Saturday, November 20, 2021 4:07 PM
To: John Dobbins <[email protected]>
Cc: [email protected] <[email protected]>
Hi John,
I don’t think that what you are doing has ever been tested. It works on ADPilatus, where the driver checks the file creation time. But I don’t think that check is done in ADEiger. Even if it were done, if the clocks are not synchronized it won’t work. Can you use the Stream interface instead as a workaround?
Sent from my iPhone
On Nov 20, 2021, at 2:55 PM, John Dobbins via Tech-talk <[email protected]> wrote:
All,
The ADEiger documentation reads:
"The generated files will be downloaded either if DataSource is set to FileWriter or if SaveFiles is set to Yes. Files are downloaded as soon as they are available."
What does "as soon as they are available" mean, i.e. how is availability determined?
I asked because we encountered a problem in which the IOC was downloading stale files from the previous acquisition.
The PV, EIG500:EIG:FWAutoRemove was set to 'No', and EIG500:EIG:FWNamePattern was constant, so with each acquisition the files get overwritten on the DCU. The IOC was grabbing old files before they got overwritten.
There was a time discrepancy between the DCU and the IOC. Would that lead the IOC to determine the files were available when in fact they weren't.?
ADEiger version = 2.5
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
Re: ADEiger/Filewriter question Mark L Rivers via Tech-talk
ADEiger/Filewriter question John Dobbins via Tech-talk
Prev: Re: ADEiger/Filewriter question Mark L Rivers via Tech-talk
Next: Re: ADEiger/Filewriter question Mark L Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
