1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Phoebus Image Decompression
From: "Kasemir, Kay via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, "Smith, William" <[email protected]>
Date: Mon, 22 Nov 2021 17:33:08 +0000
Hi Will,
> Does Phoebus image viewer work with area detector compressed images sent over PV access? I.E can it read the compression type from the PV access protocol and perform the decompression?
At this time, regrettably, no. The relevant code is in https://github.com/ControlSystemStudio/phoebus/blob/master/core/pv/src/main/java/org/phoebus/pv/pva/ImageDecoder.java
In principle, it's straight forward to add something like `struct.get("compression")` to determine how the data is compressed, and to then un-compress the `value`.
If you have some actual test data and information on how to decode the compressed image, please go ahead and implement it.
Kay
RE: Phoebus Image Decompression Mark L Rivers via Tech-talk
Phoebus Image Decompression Smith, William via Tech-talk
Prev: Phoebus Image Decompression Smith, William via Tech-talk
Next: Control Systems Developer + DevOps Role at Fusion Startup Josh Fiddler via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: RE: Phoebus Image Decompression Mark L Rivers via Tech-talk
