Hello, However if I group multiple NTTable types in one PVObject then the Phoebus Table widget is unable to display the same. (I am doing so with the proper path pva://my_object/Table1, pva://my_object/Table2). I tried playing with this code https://github.com/ControlSystemStudio/phoebus/blob/master/app/display/model/src/main/resources/examples/table/server.py. (i tried changing the dingus table to NTTable type) but the moment I place the "epics:nt/NTTable:1.0" structure at a lower lever in the pvobject structure the Table widget is unable to display the same. I wanted to reduce the clutter of pva objects Thank you in advance Regards, Kuldeep Joshi
ANJ, 26 Nov 2021 |
![]() · Download · Search · IRMIS · Talk · Documents · Links · Licensing · |
