1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: PVAccess server in python.
From: Michael Davidsaver via Tech-talk <[email protected]>
To: Kuldeep Joshi <[email protected]>
Cc: [email protected]
Date: Sun, 28 Nov 2021 19:31:55 -0800
On 11/25/21 10:07 PM, Kuldeep Joshi via Tech-talk wrote:
> Hello,
> I understand that the PVAccess protocol sends only the data that changed.
> I was seeing some demo codes in phoebus using PVAccess https://github.com/ControlSystemStudio/phoebus/blob/master/app/display/model/src/main/resources/examples/table/server.py <https://github.com/ControlSystemStudio/phoebus/blob/master/app/display/model/src/main/resources/examples/table/server.py>. where the whole structure is updated.
With P4P change tracking is mostly automatic.
https://mdavidsaver.github.io/p4p/values.html#change-tracking
> In my case the top level PVA object is epics:nt/NTTable:1.0 .I wanted to incrementally add the data to the table.
However, I don't think this will help you much in the case of
NTTable as the PVA delta encoding operations on whole fields.
So an array field, like those which represent each columns of
a NTTable, will always be sent in their entirety.
So eg. if the contents of a column don't change, then there is
no need to re-send.  However, if one cell is changed, added,
or removed, then the entire column needs to be re-sent.
For this reason I would suggest thinking in terms of publishing
a new set of rows with each subscription/monitor update, and not
of appending as this will necessitate inefficient duplication
over the network.
> How do I do so?
> PS: I am new to PVAccess
> Regards,
> Kuldeep
PVAccess server in python. Kuldeep Joshi via Tech-talk
Prev: PVAccess server in python. Kuldeep Joshi via Tech-talk
Next: Re: CSS (Eclipse and Phoebus) super slow on a server with multiple users Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Next: MVME3100 boot failure at "Trying to find CSR on VME" Peter Linardakis via Tech-talk
