1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: ADPilatus $(P)$(R)FileFormat ?
To: John Dobbins <[email protected]>
Date: Tue, 30 Nov 2021 17:22:22 +0000
Hi John,
You are correct to be confused.
The FileFormat PV comes from the asynNDArrayDriver base class, and is documented here:
https://areadetector.github.io/master/ADCore/NDArray.html#asynndarraydriver
However, that PV is not used in the ADPilatus driver, and so does not belong on the OPI screens.  I have removed the PVs from the OPI screens and tweaked the layout.  I have pushed to the master branch of ADPilatus on Github.
From: Tech-talk <[email protected]> On Behalf Of John Dobbins via Tech-talk
Sent: Tuesday, November 30, 2021 10:52 AM
To: [email protected]
Subject: ADPilatus $(P)$(R)FileFormat ?
I want to write cbf files from a Pilaus detector.  I understand this is selected by the choice of the file extension in $(P)$(R)FileTemplate.
On the MEDM screen I also see a $(P)$(R)FileFormat menu mux which offers the choices TIFF | Invalid.
This PV isn't mentioned in the documentation:
So, I am a little confused. Thanks.
John Dobbins
Research Support Specialist
Cornell High Energy Synchrotron Source
Cornell University
ADPilatus $(P)$(R)FileFormat ? John Dobbins via Tech-talk
Prev: ADPilatus $(P)$(R)FileFormat ? John Dobbins via Tech-talk
Next: Dropdown menu problem when running Phoebus inside a Docker container Oscar Ibañez via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
