1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Trying to use elauncher: _main_ thread failed
From: "Crisp, Daniel via Tech-talk" <[email protected]>
Cc: "Barofsky, Daniel" <[email protected]>
Date: Mon, 6 Dec 2021 21:03:34 +0000
I don't see much documentation about what we call 'elauncher' here, so I'm thinking it might be something site specific? In any case, It's what we use to add PVs that trigger python scripts to our IOCs. I've attached the source code we add to our src/ folder. We also have an elaunchSupport.dbd file that simply contains two lines 'device(bo, INST_IO, devLauncher, "Launcher")'' and 'variable(launcherVerbose, int)'.
I'm getting an error when attempting to start the IOC, and I'm wondering if someone here could enlighten me as to the problem:
A call to 'assert(prec->out.type == INST_IO)' by thread '_main_' failed in ../launcher.c line 80.
Dumping a stack trace of thread '_main_':
[    0x7f95a3285283]: /lib/x86_64-linux-gnu/libCom.so.3.15.8(epicsStackTrace+0x73)
[    0x7f95a327e7af]: /lib/x86_64-linux-gnu/libCom.so.3.15.8(epicsAssert+0x4f)
[    0x5604d5f29b2f]: ../../bin/linux-x86_64/hlc_s800(add_record+0x4f)
[    0x7f95a3309ea7]: /lib/x86_64-linux-gnu/libdbCore.so.3.15.8(coreRelease+0x837)
[    0x7f95a330a10a]: /lib/x86_64-linux-gnu/libdbCore.so.3.15.8(iocBuild+0x1a)
[    0x7f95a330a299]: /lib/x86_64-linux-gnu/libdbCore.so.3.15.8(iocInit+0x9)
[    0x7f95a32700fb]: /lib/x86_64-linux-gnu/libCom.so.3.15.8(gphDump+0x125b)
[    0x5604d5f1fea2]: ../../bin/linux-x86_64/hlc_s800(main+0x12)
[    0x7f95a309e09b]: /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xeb)
[    0x5604d5f1fefa]: ../../bin/linux-x86_64/hlc_s800(_start+0x2a)
EPICS Release EPICS R3.15.8-2+0~20201111173402.6+debian10~1.gbp133abb.
Local time is 2021-12-04 14:33:29.880008830 EST
Please E-mail this message to the author or to [email protected] epicsThreadSuspendSelf()
#include <stdlib.h>
#include <string.h>
#include <epicsString.h>
#include <epicsAssert.h>
#include <cantProceed.h>
#include <epicsThread.h>
#include <epicsMutex.h>
#include <epicsEvent.h>
#include <callback.h>
#include <epicsExit.h>
#include <errlog.h>
#include <dbStaticLib.h>
#include <alarm.h>
#include <dbEvent.h>
#include <dbAccess.h>
#include <recSup.h>
#include <devSup.h>
#include <alarm.h>
#include <boRecord.h>
#include <recGbl.h>
int launcherVerbose = 0;
typedef struct {
    epicsMutexId lock;
    epicsThreadId thread;
    epicsEventId start;
    boRecord *prec;
    unsigned int running:1;
    unsigned int done:1;
    char *cmd;
    int ret;
} work;
static void worker(void*);
static void cleanup(void*);
static long init_record(boRecord* prec)
    return 2;
static long add_record(dbCommon* pcom)
    DBENTRY entry;
    boRecord *prec=(boRecord*)pcom;
    work *priv=prec->dpvt;
    if(!priv) {
        priv=mallocMustSucceed(sizeof(*priv), "elauncher malloc");
        prec->dpvt = priv;
        priv->lock = epicsMutexMustCreate();
        priv->start = epicsEventMustCreate(epicsEventEmpty);
        priv->prec = prec;
        priv->cmd = NULL;
        priv->ret = -1;
        priv->running = 0;
        priv->done = 0;
        priv->thread = epicsThreadMustCreate("launcher",
                                             epicsThreadPriorityMedium,
                                             epicsThreadGetStackSize(epicsThreadStackSmall),
                                             &worker, priv);
        epicsAtExit(&cleanup, priv);
    assert(prec->out.type == INST_IO);
    dbInitEntry(pdbbase, &entry);
    dbFindRecord(&entry, prec->name); /* can't fail */
    if(dbFindInfo(&entry, "cmd")==0) {
        priv->cmd = epicsStrDup(dbGetInfoString(&entry));
    } else {
        priv->cmd = epicsStrDup(prec->out.value.instio.string);
    if(launcherVerbose || !priv->cmd || strlen(priv->cmd)==0)
        errlogPrintf("%s: cmd '%s'\n", prec->name, priv->cmd);
    assert(priv->cmd);
    dbFinishEntry(&entry);
    return 0;
static long del_record(dbCommon* pcom)
    if(!priv)
        return -1;
    if(priv->running)
        return -1;
    free(priv->cmd);
    priv->cmd = NULL;
    return 0;
static long write(boRecord* prec)
    if(!priv || !priv->cmd)
        return -1;
    prec->udf = 0;
    if(!prec->pact) {
        /* ensure 1-> 0 transition on completion */
        prec->mlst = prec->val;
        prec->val = 1;
        db_post_events(prec, &prec->val, DBE_VALUE|DBE_LOG);
        priv->running = 1;
        epicsEventSignal(priv->start);
        prec->pact = TRUE;
        if(launcherVerbose)
            errlogPrintf("%s: start\n", prec->name);
        return 0;
    } else {
        prec->pact = FALSE;
        if(WIFSIGNALED(priv->ret)) {
            recGblSetSevr(prec, WRITE_ALARM, INVALID_ALARM);
        } else if(WEXITSTATUS(priv->ret)) {
            recGblSetSevr(prec, WRITE_ALARM, MAJOR_ALARM);
        prec->val = 0;
        if(launcherVerbose)
            errlogPrintf("%s: done\n", prec->name);
    return 0;
static void worker(void *raw)
    work *priv=raw;
    while(1) {
        char *cmd;
        int ret;
        epicsEventMustWait(priv->start);
        if(priv->done) {
            priv->done = 0;
            return;
        dbScanLock((dbCommon*)priv->prec);
        if(launcherVerbose)
            errlogPrintf("%s: run\n", priv->prec->name);
        cmd = epicsStrDup(priv->cmd);
        dbScanUnlock((dbCommon*)priv->prec);
        ret = system(cmd);
        if(launcherVerbose)
            errlogPrintf("%s: complete\n", priv->prec->name);
            unsigned int d=WTERMSIG(ret);
            errlogPrintf("%s: command terminated with signal %u\n   '%s'\n",
                         priv->prec->name, d, cmd);
        free(cmd);
        priv->ret = ret;
        priv->running = 0;
        (*priv->prec->rset->process)(priv->prec);
static void cleanup(void *raw)
    work *priv=raw;
    priv->done = 1;
    while(priv->done)
    if(launcherVerbose)
        errlogPrintf("%s: worker stopped\n", priv->prec->name);
static
dsxt extLauncher =
    &add_record, &del_record
static long init(int pass)
    if(pass==0)
        devExtend(&extLauncher);
    return 0;
static
struct {
    dset com;
    DEVSUPFUN write;
} devLauncher =
{5, NULL,
    (DEVSUPFUN) &init,
    (DEVSUPFUN) &init_record,
    NULL
    (DEVSUPFUN) &write
#include <epicsExport.h>
epicsExportAddress(dset, devLauncher);
epicsExportAddress(int, launcherVerbose);
Re: Trying to use elauncher: _main_ thread failed Johnson, Andrew N. via Tech-talk
Re: Trying to use elauncher: _main_ thread failed Hu, Yong via Tech-talk
Prev: Infinite FLNK loop Daykin, Evan via Tech-talk
Next: Re: Infinite FLNK loop Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: Infinite FLNK loop Johnson, Andrew N. via Tech-talk
Next: Re: Trying to use elauncher: _main_ thread failed Johnson, Andrew N. via Tech-talk
