1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Need clarification on UDP Broadcasting to multiple IOCs on same PC
From: "Manoussakis, Adamandios via Tech-talk" <[email protected]>
To: tech-talk <[email protected]>
Date: Tue, 7 Dec 2021 18:29:55 +0000
Hello All,
I have been trying to understand the UDP broadcast requests when having multiple IOCs running on a single host (ubuntu).  I am using the script from https://wiki-ext.aps.anl.gov/epics/index.php/How_to_Make_Channel_Access_Reach_Multiple_Soft_IOCs_on_a_Linux_Host and the rule is in place on my host:    0     0 DNAT       udp  --  any    any     anywhere             ubuntu               udp dpt:5064 to:192.168.252.255.  My confusion comes from that when I hook up wireshark to my local interface I am seeing traffic from caget requests but don’t seem to see the broadcast going out (192.168.252.255:5064).  The rule seems like any source traffic pointed at my hostname should get funneled to the broadcast address.
I am running into an issue with my gateway where the gateway is not able to reach all the IOCs but without the gateway it seems to work with the 10 IOCs I have running.  But now I am not so sure its due to the prerouting rule and might be some other magic happening?
Adam
Re: Need clarification on UDP Broadcasting to multiple IOCs on same PC Ralph Lange via Tech-talk
Prev: How to put the contents of a file in a waveform record Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
Next: Re: Need clarification on UDP Broadcasting to multiple IOCs on same PC Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: How to put the contents of a file in a waveform record Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
