1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: RE: FLIR Camera with AD Spinnaker losses ID
From: "Smith, William via Tech-talk" <[email protected]>
To: Mark Rivers <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 8 Dec 2021 12:09:32 +0000
Hi Mark,
I conducted a few more tests to answer your questions:
  1. The error happens when only one camera is acquiring, as well as when all are acquiring
  2. They are running in separate IOC’s.
In total I have only 100MBs of bandwidth available on the network. I am using a dedicated NIC on my server for the cameras, this peaks at about 25MBs during acquisition with the one camera.
  1. All three cameras are running the same firmware version
  2. I have tried to repeat the error with the SpinView program and I can. I think this last point probably shows it’s a camera problem, I will contact FLIR
Will
Sent: Tuesday, December 7, 2021 2:35 PM
To: [email protected]; Smith, William <[email protected]>
Subject: Re: FLIR Camera with AD Spinnaker losses ID
Hi Will,
  • Does the error happen when only a single camera is running at once, or only when multiple cameras are running at the same time?
  • If the latter, then are they running in one IOC or 3 IOCs, and what is the total amount of Ethernet bandwidth being used?
  • Are all 3 cameras running the same firmware version?
  • Have you tried to reproduce the problem using the FLIR SpinView program?
From: Tech-talk <[email protected]> on behalf of Smith, William via Tech-talk <[email protected]>
Sent: Tuesday, December 7, 2021 6:41 AM
To: [email protected] <[email protected]>
Subject: FLIR Camera with AD Spinnaker losses ID
I am using a FLIR blackfly_50A2M_CS camera with Area Detector version 3.1 EPICS R7.0.4.1 on Ubuntu 20.04.
I can acquire images with one camera, with 2 other cameras with identical settings I can acquire images for some amount of time and then I get a bunch of errors in iocsh all of the following pattern:
“exception Spinnaker: Error reading from device [SN:Unknown], at register address: F0F8000C. Please try reconnecting the device. [-1010]”
Given that I see this problem with 2 cameras and not one I think it’s a problem with the cameras. Before I contact FLIR I wanted to see if anybody else here had seen a similar problem?
Thanks
Will
Aufsichtsrat: Vorsitzender Dr. Volkmar Dietz, stv. Vorsitzende Dr. Jutta Koch-Unterseher
Geschäftsführung: Prof. Dr. Jan Lüning (Sprecher), Prof. Dr. Bernd Rech, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
14109 Berlin
Deutschland
Postadresse:
14109 Berlin
Deutschland
FLIR Camera with AD Spinnaker losses ID Smith, William via Tech-talk
Re: FLIR Camera with AD Spinnaker losses ID Mark Rivers via Tech-talk
Prev: Re: PyDevice and an IOC Florian Feldbauer via Tech-talk
Next: Re: PyDevice and an IOC Josh Fiddler via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Re: FLIR Camera with AD Spinnaker losses ID Mark Rivers via Tech-talk
Next: How to put the contents of a file in a waveform record Cobb, Tom (DLSLtd,RAL,LSCI) via Tech-talk
