1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Subject: Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers?
To: "[email protected]" <[email protected]>, Mrinal Bera <[email protected]>
Date: Wed, 8 Dec 2021 14:18:29 +0000
Hi Mrinal,
There is now a 10-axis version of the MAXnet, so you could use just 2 of them.  The MAXnet driver inherits from asynMotorController, so it should definitely support multiple controllers in the same IOC.  Each is a separate asynPortDriver object with a different asyn port name.
If you are planning to use this on a beamline that already has many VME cards like the OMS MAXv then I wonder if it is the best solution.  You will need to build a box with power supply and connectors for the MAXnet, while adding from more MAXv cards is simpler.  If you want an Ethernet solution there are more powerful controllers available that already have nice packaging.
From: Tech-talk <[email protected]> on behalf of Mrinal Bera via Tech-talk <[email protected]>
Sent: Wednesday, December 8, 2021 3:13 AM
To: [email protected] <[email protected]>
Subject: Can single soft-IOC control multiple OMS SPI-MAXnet controllers?
While looking for 18 axis application, I came across the OMS SPI-MAXnet 8000 8-axis controller. For the 18 axis application, I would need 3 of such controllers. As the EPICS motor record support OMS-MAXnet controllers, would it be possible to configure all the three controllers under a single soft-IOC, or do I need to run 3 separate soft-IOCs?
Best,
Mrinal
Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mrinal Bera via Tech-talk
Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Kevin Peterson via Tech-talk
Prev: Re: [EXTERNAL] PyDevice and an IOC Vodopivec, Klemen via Tech-talk
Next: Re: [EXTERNAL] PyDevice and an IOC Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  <2021>  2022  2023  2024  2025  2026
Prev: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mrinal Bera via Tech-talk
Next: Re: Can single soft-IOC control multiple OMS SPI-MAXnet controllers? Mrinal Bera via Tech-talk
